Eleven Rack VS Marshall - FOR LIVE USE
Hi, I bought the Eleven Rack a month ago and it sounds great in my home studio with headphones. Now Im in the process of buying a guitar amp for my band (looking at a Marshall JVM Combo), so I thought of using Eleven Rack live. Ive done the steps from the videos how to change the output options from the preferences within Eleven rack to Rig output without cab (Ive tried all the options: amp input, amp output, rig input, rig output and rig output no cab) since Ive tried connecting it to both Marshall combos and also stacks. My problem is that it still sounds very "thin" (compared to a nice "warm" tube sound that I get when I plug my guitar right in to the Marshall. Maybe I have to do tweaking with EQs and stuff on the Eleven rack, but I just dont understand, it sound good enough in the headphones. Of course, getting a power amp (maybe Crown) would be the next step to not alter the sound of the Eleven rack too much with any other amp, its just that after buying the Eleven rack, Im a bit short of funds and if it doesnt sound good enough for me with a power amp and a cab (compared to a marshall tube amp), Im standing there with quite a bit of equipment that Im not satisdied with. I love the idea of using Eleven rack, to be able to use the same sounds in my home studio as on the gigs, its just that with all the three different Marshalls Ive tried it with so far, it just sounds so thin, no real "body" of the sound, Ive tried different cables, so dont think its that. Thanks for taking your time! Cheers Tom |
Re: Eleven Rack VS Marshall - FOR LIVE USE
Hi Tom, where on your Marshall did you connect the "Output to Amp" cable from the 11R to?
To use the 11r live, in my opinion you have two options
1) xlr Left Main output -> house PA. xlr Right output -> powered floor monitor or in-ear monitor. 2) both xlr outputs -> stereo power amp (ex Rocktron Velocity 300)-> clean cab of your choice. You can then mic this cab and send that to a PA if needed. Because the amp and cab modeling in the 11r sounds so good you would really be missing out if you bypass it. If you do you've reduced the 11r to an expensive fx processor. Personally I would not go thru the Marshall because both the power section and speakers will adversely "color" the 11r sound. This is just my opinion and I hope it helps.
Self Built PC: Core i5 3570K @3.4 Ghz | Asus P8Z77-V LK 8 Gigs Corsair XMS 1600 | XFX HD4870 120GB OCZ Agility 3, 2 TB WD Green Windows 7 Home Premium 64bit Pro Tools 8.0.5 M-Audio Keyrig 49 Eleven Rack w/ERXP FCB1010 | Mackie SRM450v2 | Taylor 314ce | Ibanez RG321MH | ESP Horizon NT-II DSBS |
Thanks both of u for ur replies!
I connected the output from the 11r to the (normal) input of the marshall. There could prob also be options to connect it to things like FX loop, but I want to use 11r not just for the FX, so will prob have to go to my local shop n c if I can try to plug my 11r into a power amp and a cab n c how it sounds. Its just that I dont really care about millions of dist sounds, I just want to find ONE nice good warm tube like clean sound n work from there. Anyone tried the 11r through a power amp and cab? sounding nice n warm with clean sound? Thanks again for ur answers! |
heres a youtube link of a guy using the 11r thru a Rocktron Velocity 300 into an old VHT 4x12 cab
http://www.youtube.com/watch?v=fYq7DfKGiUw sounds pretty good to me. edit: looks like he turned off the cab simulation.
guitar>11r>fx in on the amp. This bypasses the the preamp section and lets you use the power section of the Marshall. Pluging it into the guitar input could damage the marshall's pre.
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
As other people have, said you'll be much better off going into you amps FX loop, so you don't get the extra coloration of the preamp. You may also want to set the Presence to zero, and use the Presence control in the Eleven Rack amp models.
If you don't have an FX loop, you can go into the preamp input, but to minimize coloration from the preamp you'll probably get the best results by setting the Mid to 10 and the Bass and Treble to 0. If there is a bright switch, set it to off.
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
Thanks for that!
I will try that. iF so many artists say its sounds amazing live, then I must do something wrong. Hope it works. Cheers! |
When I tested the 11R at GC, they plugged it into the Serial Loop Return of a Diezel VH4 and into a Mesa 412. With the cabinet modeling turned off it sounded phenomenal.
Through a QSC K10 with the cab modeling turned on, I felt it needed an external 31 band equalizer. But then pretty much everything needs EQ anyway. It still sounded good, but because it was now a recorded amp tone it lost the "amp in the room" feel. That will happen with any modeler. The recorded tone was excellent for a recorded tone, and of course this is what people hear from FOH. But anyway, have fun.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Eleven Rack - Marshall Clips | jonathanwolst | Eleven Rack | 11 | 09-17-2013 09:54 AM |
For Sale: Eleven Rack live rig | synergyscott | Eleven Rack | 1 | 10-11-2012 11:43 AM |
Live Recording of Eleven Rack | Chad Pippin | Eleven Rack | 9 | 02-09-2011 11:16 AM |
Eleven Rack Live + MIDI | Charbs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-29-2010 10:12 AM |
Is Bob Weir using the eleven rack live?? | paulreed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-19-2010 09:13 AM |
