Cannot Change Hardware Buffer Size
Pro Tools M-Powered 7.1 / Windows XP / M-Audio FireWire 1814
I recently re installed 7.1 and now the only option in the hardware buffer size drop down menu is 512 Samples. Any suggestions. |
Re: Cannot Change Hardware Buffer Size
I have now uninstalled 7.1 and installed 7.4.
Now the only hardware buffer size option I have is 256 samples. Any suggestions? |
I don't know the answer, but have you tried setting the buffer size in the M-Audio Firewire Control Panel?
Harware Buffer Size
Yeah, I'm having the same problem. But when I set the buffer size on the M audio control panel, it seems to jump from whenever I set it to (1024 samples in this case) back down to 128?! Then After about 5 mins of playback the sound goes to Bit Crushy Hell and sounds like an old Nintendo game. Then I reboot just to get another 5 mins outta the programe. Just installed the ProFire litebridge with m-powered 7.4cs. Not sure what to do here....
Cannot change hardware buffer size on DIGI003 | krazylain | Windows | 14 | 10-28-2016 08:22 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Can't Change Buffer Size? | sajack23 | Windows | 5 | 08-05-2012 05:29 PM |
Can't change buffer size | zkarssli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-26-2010 06:49 PM |
Can't change H/W Buffer Size | DestinysEnd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-07-2001 12:20 AM |
