Old 06-12-2017, 01:06 PM
giroserex giroserex is offline
Default General question about older TDM plugs
Pretty simple question, when did avid switch from all-fixed point mixing engine to float?
It seems TDM plugins started to get phased out roundabout HD8 period, judging by a quick search around, and that float engine was introduced in perhaps 8.1+. I know LE uses the newer float engine.
Aynone know ?
Cheers (I don't own a PT system yet)
Giro
dislikes dials with 0.01% increments
Old 06-12-2017, 02:07 PM
Default Re: General question about older TDM plugs
Why is there a Mandarin Duck there top left of the board???
Old 06-12-2017, 03:03 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
The forum used to be called the Digidesign User Community (DUC), so that's why the Duck.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 06-12-2017, 03:30 PM
I see,
You use XP? That makes two of us.. uncheck automatic updates, avoid you some 1000 eventual, costly, problems
Old 06-12-2017, 03:36 PM
Ya, still on XP. My old equipment and XP suits my needs. I do have the Music Production Toolkit, which gives me Beat Detective, Sound Replacer, MP3 option, 48 track count, and a few other features not originally included with PT LE.
My PT rig is not connected to the internet. I disabled the network adapter in the device manager. Only when I want to back up sessions to my other computer on the home network, do I enable the network adapter, copy the files, and then disable.
Old 06-12-2017, 03:49 PM
32gb ram though!! I'm so tempted hahahaha is there even a limit anymore on those newer OSes I wonder, not that its relevant to the topic at hand, cough
Old 06-12-2017, 03:54 PM
The RAM limitation is going to be more a function of your motherboard. Windows 10 Pro has a 2 TB limit, Windows 8 Pro 512 GB limit. The home versions have lower limits.
Old 06-12-2017, 09:02 PM
TDM plugins work up thru Pro Tools 10HD(assuming you have HD cards and IO). Pro Tools 11 was the big changeover to AAX and AAX-DSP(with HDX cards).
Old 06-13-2017, 05:35 AM
Okay I know I wrote plugs in the thread title but I was more interested in the mixing engine...
When did avid formally introduce float mixing, PT8 / PTHD8 (which I assume mean the same)?
Off to eat waffles...
Old 08-04-2017, 04:18 PM
MatzeHD MatzeHD is offline
If you work with a HD Card System, then your Protools Mixer are running with 48Bit all-fixed point with TDMII Bus and this was supported until Protools 10.
The older Mix24 Card Systems are running with 24Bit all-fixed point Mixer and was only compatible until Protools 6.4 or so and this was TDM1.
If you have a ProtoolsHD Native System, may be since Protools 9 or 10(?) the Mixer Engine runs with 32Bit(or 64Bit?) floating point, but only with CPU Hosting without DSPs.
If you have a HDX DSP System, available since Protools 10, this runs with 64Bit Floatingpoint Mixer Engine!
TDM Plugins works only on TDM DSP Systems and on HDX too(?)
AAX Plugins works only on normal "CPU" Protools, HD Native and HDX DSP Systems since Protools 10.
I hope this all was correctly! :)
How to Register Older Oxford Plugs?? mrhappy1997 RTAS & TDM Plug-ins 2 06-09-2016 11:45 PM
Question about an older Mac Pro and possible older versions of Pro Tools HD wolfman_rob Pro Tools TDM Systems (Mac) 13 07-21-2013 01:29 AM
General Venue Automation Question - (Maybe dumb question) TwoPort VENUE Live Sound Systems 5 12-21-2007 02:41 PM
General Midi Question and another stupid question... imcivor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-04-2007 02:39 PM
general question? reverieman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-12-2006 10:01 PM
