Old 04-21-2016, 04:19 AM
veryape135 veryape135 is offline
Default Pro Tools 11 With Source connect
Hi all,
We are looking into running VO sessions using Pro tools 11 with Source connect. I'd like to get some feed back from engineers that have used this set up to run VO sessions between locations regarding the stability of the connection between source connect clients.
Thanks!
Veryape135
VeRYApE
____
Old 04-21-2016, 10:05 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro Tools 11 With Source connect
I'm going to chime in here as a recent purchaser of Source-Connect Standard. I have yet to use it in a session myself, but for those I talked to prior to purchase, stability is almost totally predicated on the quality of the Internet at both ends of the session. I'm typically getting over 300 Mbps down and over 20 Mbps up, more than enough for Source-Connect according to their specs.
While it is an additional expense ($75 US) I do plan to shortly get Certified by Source-Elements, not to assure potential clients I know how to run a Source-Connect session, but rather to assure potential clients that Source-Elements have certified my Internet connection as suitable for Source-Connect.
HTH
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 04-22-2016, 04:57 AM
Thanks for response, great info. Were setting up now it looks like the only issue were going to have is a combination of the port forwarding and our IT service providers seemingly endless number of firewall conditions.
VeRYApE
____
Old 04-22-2016, 04:24 PM
The Weed's Avatar
I had little to no issue setting up port forwarding. If you need some help, email me at info at brucehayward dot com. If you want, we can Skype, just email me when you want to. If you do get set up correctly and want to do a Source-Connect session, I'm up for that too.
Cheers,
Source Connect NYC MIKEROPHONICS Post - Surround - Video 4 08-23-2011 05:39 AM
Source ZIP- a new nifty utility from those Source Connect People MIKEROPHONICS Pro Tools TDM Systems (Mac) 0 01-13-2010 09:05 AM
Pro Tools Source Connect VO Session in LA minister Post - Surround - Video 10 02-22-2007 08:25 AM
source-elements.com/Source-Connect clusterer Pro Tools TDM Systems (Mac) 3 10-30-2005 05:16 AM
Source-Connect 1.0 Big World Pro Tools TDM Systems (Mac) 2 03-16-2005 03:50 PM
