PT8 and PT9 session exchange hell
did anyone ever transported a session with busses and everything from PT9 to PT8? this is hell... I mean it took me 30 min to just re-arrange all the busses with reverbs and mix busses and get where I was in PT9 LE
how complicated can you go with compatibility..? crazy - and I mixed 11 session in LE before movin to HD3... |
Re: PT8 and PT9 session exchange hell
I've had no issues with importing PT9 sessions into PT8 on my current feature other than the pop-up dialog that says they came from a newer version of PT. After clicking through that dialog, the sessions import exactly as if they had been from PT8.
What problems are you experiencing? |
the whole problem starts when I import session data from my mix session template I created with PT8 into PT9
lets say I import 3 reverbs and 3 delays from bus 1 to bus 6 (each one with a mono bus) into my actual session on PT9 - when I was on PT8 on HD and LE I usually did this without problems imorting it and the imoprted busses replaced the existing - great stuff... now when I'm importing session data into protools 9 it doesnt replace them it kinda creates a bus menu b (...?? what for??) and places them anywhere which means NOT on bus 1-6 then going back to PT8 HD with my PT9 session I dunno what it does exactly but now my reverbs and sends are after bus 128 |
If you have undergone through massive buss or i/o change, it is easier to import session data into a fresh session instead of opening a session created by older PT version.
Just my experience...
you need to first open your template in PT 9 save it then import from that.
The bussing and I/o completely changed from Version 8 to 8.1 and 9 to accommodate HEAT and other Mixer bus plugs i believe. once you wrap your head around it. it is much better no more numbers... but yeah to make your life easier Save a Version 9 template for yourself. upon opening you template you shouldn't have to change anything then when you import from it everything should stay where you want it. kd |
Session Exchange TDM to LE? | ran | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-04-2005 08:17 PM |
G5 to G4 session exchange..is there an issue??? | soundmatters | Pro Tools TDM Systems (Mac) | 1 | 05-12-2004 11:45 AM |
Session exchange between 5.1TDM+G3 and 5.1LE+Win98 | stijnnorga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-22-2003 07:40 AM |
Session exchange: win LE => mac LE => mac FREE | tubaz | Digidesign Hardware & Software | 2 | 05-02-2002 12:31 AM |
PT 24 Mix / Session 8 PC exchange | Joao Braga | Pro Tools TDM Systems (Win) | 3 | 02-19-1999 08:34 AM |
