Oxygen49 MIDI controller powers itself off!!!
I'm running PT8 LE on a mac 10.5.8. reason is slaved. both recognize the maudio controller. I somehow switched to plugin map mode but couldnt figure out how to map to a plugin. and now cant switch back to 'normal' mode. i turned a knob and BAM the oxygen49(blue) turns off (Led goes out) i turn unit off manually and then back on and its ok just to do the same thing again when i turn a knob. HELP!!!
Re: Oxygen49 MIDI controller powers itself off!!!
well if anyone reads this and has a similar problem, the fix was you need to be running PT 8.0.1 or higher. i was only running 8.
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
Newbie help required! Hooking up Oxygen49 to Pro-Tools M-Powered Essentials | Amarnaman | Pro Tools M-Powered (Win) | 0 | 02-28-2012 09:17 AM |
Help setting up an Oxygen49 controller | Evilmoosehead | Virtual Instruments | 3 | 08-31-2011 08:41 AM |
Pro tools not recgognizing Oxygen49 | play4theworld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-18-2011 02:02 PM |
Help trying to control pro tools w/ oxygen49 midi controller | aidanm | Pro Tools M-Powered (Mac) | 1 | 07-02-2007 07:44 AM |
