Everything crashes constantly!
I bought my MacBook refurbished in mid 2007. It ran perfectly until a couple of months ago. I bought ProTools for my recording class at school and had to upgrade from Tiger to Leopard. I immediately started having programs crash. I assumed it was because PT is power hungry. I uninstalled PT and my computer worked fine until I reinstalled it. So I am convinced it is a PT or Mbox issue. The salesman at Sweetwater told me I should be using a Firewire external HD instead of my USB. So I sold my USB and bought a Firewire HD. I also upraded my RAM from 2 to 4 GB at the same time. I was told this would take care of all my problems. But is has not. I think it has actually gotten worse. I have repaired the disk, no luck. Reinstalled Leopard 2 or 3 times, no luck. If try to repair the disc permissions in Disk Utility, it gives me a long list of items that need repaired, but never repairs them. I click repair, but when it is done and I go back and click verify to see if it is fixed, I get the same list all over again. The guy at Sweetwater said there is something seriously wrong with my computer. What has gone wrong?!
Re: Everything crashes constantly!
hi,
first we need to know: do you use the correct compatible PT and plug-in versions for leopard? have you follow the troubleshooting thread in this forum? does your Firewire Harddisk have a qualified Oxford Bridge Chip (911,924 etc.)? I cannot find any clues for this in your post. best
last: PT11.3.1 |
Please explain.
Also where is the troubleshooting thread? |
are you using the MBox 2? And if so, do your freezing applications have sound enabled through the MBox 2 output? Are you having trouble with Pro Tools? Or are you having problems with other apps? Or both? Check out this thread http://duc.digidesign.com/showthread...light=Unstable |
Pro Tools 9.0.5 crashes constantly... | smoramarco | macOS | 5 | 10-09-2011 08:23 AM |
Fresh Install of 7.4.2 Crashes Constantly | aermotor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-22-2010 05:58 PM |
Pro Tools 7.4.2 Crashes Constantly | mikesmovielife | Pro Tools M-Powered (Mac) | 0 | 04-30-2009 02:21 PM |
7.2 crashes constantly | Stig Eliassen | Pro Tools TDM Systems (Mac) | 13 | 09-22-2006 02:01 PM |
PT5 crashes constantly on MDD G4. Please Help! | motord | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-28-2006 01:01 PM |
