error 6101 / 9128 CPU overload MAC PPC G5
Having trouble with error codes 6101/9128. CPU overload, remove some plugins e.t.c. Only happens with higher track count, I open a song with 4-5 tracks and a few plugins and seems fine but with larger track counts ( say 10-15) is when it starts playing up. CPU usage is only around 40% at most. tried all the optimizations recommended through Avid, to the best of my knowledge, reinstalled protools, updated drivers for profire still to no avail. Any help would be greatly appreciated. Specs below.
Protools M Powered 8.1 Profire 2626 Power Mac G5 OSX 10.5.8 Leopard Model Identifier: PowerMac7,3 Processor Name: PowerPC G5 (2.2) Processor Speed: 2 GHz Number Of CPUs: 2 L2 Cache (per CPU): 512 KB Memory: 8 GB Bus Speed: 1 GHz FireWire Bus: Maximum Speed: Up to 800 Mb/sec ProFire 2626: Manufacturer: M-Audio Model: 0x10 GUID: 0xD6C0404000002 Maximum Speed: Up to 400 Mb/sec Connection Speed: Up to 400 Mb/sec Sub-units: ProFire 2626 Unit: Unit Software Version: 0x100C1 Unit Spec ID: 0xD6C Serial-ATA Bus: Maxtor 6Y250M0: Capacity: 233.76 GB Model: Maxtor 6Y250M0 Revision: YAR51FW0 Serial Number: Y61A2Y9E Removable Media: No Detachable Drive: No BSD Name: disk1 Protocol: ata Unit Number: 0 Socket Type: Serial-ATA Bay Name: "A (upper)" Mac OS 9 Drivers: No Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Verified Volumes: OSX: Capacity: 233.64 GB Available: 195.63 GB Writable: Yes File System: Journaled HFS+ BSD Name: disk1s3 Mount Point: / Serial Number: Y61A2Y9E Removable Media: No Detachable Drive: No BSD Name: disk1 Protocol: ata Unit Number: 0 Socket Type: Serial-ATA Bay Name: "A (upper)" Mac OS 9 Drivers: No Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Verified Volumes: OSX: Capacity: 233.64 GB Available: 195.63 GB Writable: Yes File System: Journaled HFS+ BSD Name: disk1s3 Mount Point: / SECOND HARD DRIVE Serial-ATA Bus: ST31000340AS: Capacity: 931.51 GB Model: ST31000340AS Revision: SD25 Serial Number: 9QJ3SBX1 Removable Media: No Detachable Drive: No BSD Name: disk0 Protocol: ata Unit Number: 0 Socket Type: Serial-ATA Bay Name: "B (lower)" Mac OS 9 Drivers: No Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Verified Volumes: Protools: Capacity: 931.39 GB Available: 924.74 GB Writable: Yes File System: Journaled HFS+ BSD Name: disk0s3 Mount Point: /Volumes/Protools GRAPHICS/DISPLAYS GeForce FX 5200: Chipset Model: GeForce FX 5200 Type: Display Bus: AGP Slot: SLOT-1 VRAM (Total): 64 MB Vendor: NVIDIA (0x10de) Device ID: 0x0321 Revision ID: 0x00a2 ROM Revision: 2060 Displays: Acer X193HQV: Resolution: 1366 x 768 @ 60 Hz Depth: 32-Bit Color Core Image: Hardware Accelerated Main Display: Yes Mirror: Off Online: Yes Quartz Extreme: Supported X193HQ: Resolution: 1366 x 768 @ 60 Hz Depth: 32-Bit Color Core Image: Hardware Accelerated Mirror: Off Online: Yes Quartz Extreme: Supported MEMORY DIMM0/J11: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM1/J12: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM2/J13: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM3/J14: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM4/J41: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM5/J42: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM6/J43: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM7/J44: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown __________________ Hardware Overview: Model Name: Power Mac G5 Model Identifier: PowerMac7,3 Processor Name: PowerPC G5 (2.2) Processor Speed: 2 GHz Number Of CPUs: 2 L2 Cache (per CPU): 512 KB Memory: 8 GB Bus Speed: 1 GHz Boot ROM Version: 5.1.8f7 Serial Number (system): YM5090XXQPP Hardware UUID: 00000000-0000-1000-8000-0011246EBA20
Hardware Overview: Model Name: Power Mac G5 Model Identifier: PowerMac7,3 Processor Name: PowerPC G5 (2.2) Processor Speed: 2 GHz Number Of CPUs: 2 L2 Cache (per CPU): 512 KB Memory: 8 GB Bus Speed: 1 GHz Boot ROM Version: 5.1.8f7 Serial Number (system): YM5090XXQPP Hardware UUID: 00000000-0000-1000-8000-0011246EBA20 |
Re: error 6101 / 9128 CPU overload MAC PPC G5
is there anybody out there?????????????????????????????????
Hi, i have the same setup. The problem is the powermac processor. Some plugins are just cpu heavy. Most companies arent even supporting the powermac anymore, you have to have an intel mac or better. I print as much audio as i can so my plugin CPU use is minimal as possible.
Chris
http://www.youtube.com/user/RegenerationMix http://soundcloud.com/regenerationmix http://twitter.com/regenerationmix MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7 |
Thanks for your reply. It says im still only using up to 40% cpu so im not going anywhere near capacity. I used a G5 with Tiger OSX and it ran fine with LE 7.4 on an mbox2. when I play any decent amounbt of tracks with a few plugins it actually skips ahead of itself after a while and goes out of sync then tries to catch up then it will come up with the error code, where usually on my old system if it happenned at all it would just stop altogether and give the error code so not sure if that makes any difference. When you say you "print" as much audio as you can, what do you mean by that? I hate the idea of having to buy another computer, the money never stops......
by print I mean i record the audio of the plugin instead of using it as RTAs. If its a reverb, i record the audio of the reverb. If its a VI, i record the audio of the VI instead of letting it stay virtual. If its compression, i process the file with the compression. If i have a midi file, i record the audio of it.
I keep my CPU usage at 30% or less. Chris
I use a PC based system and have had the same issue in the past. I don't know if this will work on a Mac or not, BUT, go to the SET-UP menu, select, PLAYBACK ENGINE, and see how many "host processors" it says you have. Try setting that to 1 less than the actual number. That worked for me.
Also, check your CPU usage limit there. You can raise or lower it. When I changed the host processor number I haven't had that issue since. Also, a lot depends on which plug-ins you are using. If you are using any wrapped VST plug-ins, they may also be causing the issue. I've had instances where a certain wrapped plug-in was the culprit. The reason is because the wrapped VST's aren't always 100% compatible with PT and can confuse it in different ways, depending. In those cases, I was able to discover which one by instantiating them one at a time until the problem surfaced. Under normal circumstances, you should be able to have several plug-ins running all at the same time without having a CPU issue.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Are you running a separate recording drive?(sorry, I could not decipher the system details).
hey albee, thanks for your reply. Yes I am running a seperate recording drive Sata. Sorry it does look all jumbled in the specs. I changed OSX from Tiger to Leopard ( computer guy wiped tiger then ghosted it over from another machine ) Everything runs fine except for this problem. Same machine ran fine with Protools 7 M box2 on Tiger OSX, using loads of plugins, never missed a beat. Now get the CPU errors, it seems to fail around 35-40% cpu usage so im thinking this can't be right. Updated drivers for profire 2626, did all optimizations e.t.c for protools so im thinking it could be something faulty in the computer like bad ram maybe. When I did a printout of the specs of machine it all came up ok so not sure. Or something hardware type might be not so compatible with new software/ interface?? Im at a loss, any ideas would be greatly appreciated.
error 6101 / 9128 CPU overload MAC PPC G5 | johnsongs74 | Pro Tools M-Powered (Mac) | 0 | 04-12-2011 05:20 AM |
error 6101 / 9128 CPU overload MAC PPC G5 | johnsongs74 | Pro Tools M-Powered (Mac) | 0 | 04-09-2011 09:01 PM |
Error Message (-6101) & (-9128) | aldeaproducciones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-18-2009 08:20 PM |
6101 and 9128 CPU overload errors with 1 track!!! | organik | Pro Tools M-Powered (Mac) | 38 | 12-30-2006 12:18 AM |
cpu error 6101&9128 | gIbson_19 | Pro Tools M-Powered (Mac) | 0 | 10-30-2006 12:40 AM |
