Re: PT Mixing - Resulting Waveform
You might try strip silence (Ctrl+U , Cmd+U) on the bounced track , since you are probably not looking for the highest peak, but for anything above -96dB.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
You can do everything you are asking in Pro Tools... it is a very versitile program.
Pro Tools does not COME WITH a spectrul, rms or peak plugin to tell you the peaks but thats why you can ADD a plugin that does that... like the Dolby Meter 2 or the Waves WLM (just google search them) will analyze the audio tracks and give you a spreadsheet like list of peaks... It would be easy to just bounce the 2 recordings to a new track and you can see the waveform of both files bounced, although that is a very strange way to fix digital errors to each their own
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
You might take a look at Audiofile Engineering's Triumph, which may be better suited to this particular task, though personally I think you could come up with a decent workflow in ProTools for this; just might take a bit of getting used to. best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Post roll resulting in run time error | Audiokidd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-24-2009 05:09 AM |
OMF import resulting in empty tracks | laharrin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-19-2009 08:20 AM |
Midi woes resulting from upgrades | ScottFB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2007 06:17 PM |
opening 6.4LE with 6.7LE resulting in loss of data | maquisar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-19-2005 01:10 AM |
