Re: Troubleshooting with Virtual Soundcheck - S3L and PT11 - no tracks imported in PT
Audio AVB is working perfectly. I am trying now to connect data (Venue Link) over the same cable but I cannot do it. There is no Venue Link connection. Is it a matter of IP's? Should I do it through DHCP or manual address? What do I have to do to have both connections (audio and data) available? Regards, |
Yes, reinstalled. |
As Mike said, go Setup > Peripherals > VENUE > Advanced Network Settings, from there choose right port, if the port is right you will be able to choose VENUE E3 Engine under VENUE System window at the same page. If all goes well, you will then see (connected) message appear next to VENUE E3 Engine selection. When it comes to redundant AVB connection and where to pick the input to your Mac you can go different ways, I for example have one cable connected from stage to E3, the other one from stage to S3, then there is a short cable between E3 & S3 and computer is connected to the E3 (third port). Also don't forget that you do need to actually have inputs patched to channels for them to appear in Pro Tools. If you create a show file where you have no inputs assigned to channels, there will be no audio tracks created in Pro Tools. . |
Also, while attempting to "Create Session From Venue," be sure the S3L is not set to "Virtual Soundcheck Mode." I used an existing Pro Tools session to set up my Venue show file. Then when attempting to create a new PT session from the show file, I experienced what was described in the initial post. Switch the S3L back to the Stage Inputs and everything should work correctly. |
Can an SC48 do Virtual Soundcheck? | LanceK | VENUE Live Sound Systems | 0 | 03-16-2014 06:39 PM |
Advice on PC for Virtual Soundcheck | Scott Fahy | VENUE Live Sound Systems | 1 | 01-06-2011 04:19 AM |
SC48 Virtual soundcheck | Sidhu | VENUE Live Sound Systems | 2 | 04-22-2010 12:43 PM |
Video into PT for Virtual Soundcheck? | SimonInAustralia | VENUE Live Sound Systems | 11 | 03-26-2010 05:17 PM |
Virtual soundcheck | tom42107 | VENUE Live Sound Systems | 13 | 01-07-2009 08:08 PM |
