Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 09-01-2009, 11:50 AM
jba jba is offline
Default BIOS Post: 7F Msg: Disp Error
As a follow-up to my previous post (where the DD will not power on when the front power button is pressed) I removed the top cover to look and see if there was a blown fuse. While, I didn't find a fuse, I did re-seat the 3V battery. Then, suddenly, when I plugged the unit back in, it started!! However, after a few inits on the display screen, it gave the following message:
BIOS Post: 7F
Msg: Disp Error
Does this mean replacing the 3V battery will fix the issue? Have anyone ever experienced this? Do DD's just simply die after time even if they're not in use?
Thanks!
Audio Buffer Underflow Error but firewire disabled in BIOS Russell Smith Windows 7 10-29-2012 04:05 PM
Updating video card for 1st gen G5 Dual 1.8 to use 30'' disp lampmusic Pro Tools TDM Systems (Mac) 0 03-11-2007 08:19 PM
Issues with Digi 002 rack PTLE 6.4 and third disp The Resident Alien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-13-2004 07:18 AM
BIOS configuration for Error 9073 SSE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2004 09:35 PM
separate edit \ mix disp. with 2 mon.(matroxG450) jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-04-2002 01:32 AM
