  #21
Old 01-24-2018, 03:25 PM
thanos4 thanos4 is offline
Default Re: Track Presets not showing in Workspace
Thanx again guys for your quick help
I believe this should be marked as fixed
I hope this will help if anyone has the same problem
  #22
Old 01-24-2018, 03:26 PM
Originally Posted by john1192 View Post
this is good info for everyone !!! Connor Rocks !!!
Yes...Connor is the man
  #23
Old 02-06-2018, 02:35 AM
The other day i had the exact same issue again..Track presets disappeared in Locations in Workspace
I deleted again miscsettings file and relaunched pro tools..then they appeared again
Strange...
P.S this thread should be moved to 2018.1
  #24
Old 02-06-2018, 03:38 AM
Drew Mazurek's Avatar
Default Re: Track Presets not showing in Workspace [solved]
done and done.
www.drewmazurek.com
  #25
Old 10-15-2018, 08:50 AM
itsmemagic itsmemagic is offline
I'm having a similar issue on 12.8.3 where I don't have a "Save Track Preset" option at all in the menu. It's also not showing up in the Default Workspace. See screenshots.
https://www.dropbox.com/s/gzg2e8yakm...%20AM.png?dl=0
https://www.dropbox.com/s/m968ecugg2...%20AM.png?dl=0
https://www.dropbox.com/s/ynq7jimg4q...%20AM.png?dl=0
The only reason in my opinion that this might be happening is that I once opened PT11 from an external drive on the same computer, when I had AAF issues. I just tried deleting MiscSettings,WaveCache, Workspace but it did NOT fix it.
  #26
Old 10-15-2018, 01:37 PM
ChuckS ChuckS is offline
Weren't track presets introduced in 2018.x? Memory a little fuzzy.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
  #27
Old 10-17-2018, 01:49 PM
HaHa, you're totally right, it's 2018 feature only. I've used the "hack" in the past hence my confusion.
Track Presets [solved] jkeefauver Pro Tools 12 9 01-29-2018 09:36 AM
Track Presets Disappearing In Workspace? indeloon85 Pro Tools 12 1 01-29-2018 04:14 AM
The presets in the workspace window don't save... Arno Peeters Pro Tools 12 4 06-11-2017 08:43 AM
Saving Workspace Presets tangoportland Tips & Tricks 2 11-28-2015 04:36 AM
Workspace presets? Tim R. Pro Tools TDM Systems (Mac) 0 03-11-2007 05:57 PM
