Plugin/Insert application
Greetings. Pretty new to PT 12.5 but am wondering what kind of procedure to use to apply a plugin/insert to only a portion of a track. Say I have a 10 minute guitar track but only want to apply some reverb to a 2 minute portion of the track. Do I need to make a sub track or something? Thanks much...
Re: Plugin/Insert application
You would likely do it by: 1) sending the guitar track to aux track where you have your reverb and automating either the send levels or the aux output 2) insert a reverb plugin to the guitar track and automate "mix" parameter from where you want it to start and end
Of course, if you want to commit to that process at that time
One thing I learned with AS is to first duplicate the audio track. That way if I don't like what the effect did I still have the original audio to go back to. And if everything worked out I then delete the duplicate.
Thanks folks, got it figured out. The track duplication is a great safeguard...
Insert Plugin Mix + Transport | bebbo | Artist Series | 0 | 05-09-2014 04:02 AM |
Using plugin as channel insert PLEASE HELP | tmc3p | VENUE Live Sound Systems | 2 | 07-02-2012 06:56 PM |
Application/Plugin to completely randomize plug-in values | Chris Nelson | Pro Tools 9 | 1 | 07-07-2011 09:46 AM |
Application/Plugin to completely randomize plug-in values | Chris Nelson | Pro Tools 9 | 0 | 07-07-2011 09:36 AM |
insert plugin order | 4times4mil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-13-2006 03:22 PM |
