Old 05-27-2013, 08:10 PM
brianwonglh brianwonglh is offline
Default Pro Tools 9.0.6 not recognizing HD Omni
First post! :)
Hi guys, Brian here. I just have a quick query..
I updated from 9.0.5 to 9.0.6 last week, and PT has had problems reading my HD Native card. I can start PT fine, but both the mac and PT won't read the HD Native card. I'd have to do a clean uninstall, and reinstall for my mac to read the HD native card. Has this happened to anyone? I'm not really keen on reinstalling PT every morning when I get to work
The worst part of this problem is, I'd reinstall, get it back to 9.0.5, and work for the rest of the day without problems. However I'd come back to work the next day and the same problem happens again.....
Thanks in advance for your help!!
Mac OSX 10.6.8, 2x 2.4GHz Quad-Core Intel Xeon, 6GB RAM.
Avid HD Omni, Pro Tools 9 HD. Avid Mojo
Old 05-28-2013, 08:24 AM
nst7 nst7 is offline
Default Re: Pro Tools 9.0.6 not recognizing HD Omni
Did you try holding down the "N" key as you launch Protools? I found that sometimes after an update or re-install that I have to do this for it to recognize everything. You should only have to do it once and it will be fine from then on (until maybe you do another update).
Old 05-28-2013, 10:14 PM
Tried holding down the N key, got to the output dialogue, changed to HD Native, restarted computer, same result
There must be a solution to this...
Is there a way to downgrade the drivers for my HD Omni? Because when I do a full installation of PT 9.0.1 and I start PT, it says that my Omni Drivers are on a higher version that 9.0.1 can support. Perhaps I upgraded my Omni drivers to 9.0.6..
PTHD 11 native not recognizing my omni I&I Pro Tools HDX & HD Native Systems (Mac) 6 09-09-2013 08:50 AM
Pro Tools not recognizing HD Omni Upmixer Pro Tools HDX & HD Native Systems (Mac) 4 07-20-2011 05:37 AM
Pro Tools 8 Not Recognizing Reason 4 fooloof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-01-2010 07:59 PM
2 Problems: PT not recognizing plug-in and CPU not recognizing external hard drives jasonguitar Pro Tools M-Powered (Win) 0 06-28-2009 07:32 AM
Pro Tools 7 not recognizing Mbox 1 dulirious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-28-2007 03:28 PM
