A/B Two Tracks
Is there a way to A/B two tracks in Pro Tools? I am not talking about using the X-Or with Solo. I need to reverse the mutes on two track to listen in the context of a mix. The tracks are duplicates, but processed differently. Maybe I am looking at it the wrong way, but being able to reverse the mutes would make this real easy.
Re: A/B Two Tracks
Select both tracks, solo one, then press Shift+S or mute one and press Shift+M
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Re: A/B Two Tracks
Thanks, that worked. Couldn't use Solo for this but the Shift M worked for reversing the Mutes. I thought I had tried this but I see I did not have the tracks selected correctly. I see that the clips themselves must be selected, not just the tracks.
Re: A/B Two Tracks
Somewhat related, the plugin sample magic AB is an affordable and convenient A/B for reference tracks and you can store the reference files in it as a preset. I recommend setting ref tracks to like -15db so you’re not smashing your mix buss to match loudness of red tracks.
Sent from my iPhone using Tapatalk |
Re: A/B Two Tracks
Here's an alternative method that I always use. Don't know how clear it is from this screengrab :http://duc.avid.com/attachment.php?a...1&d=1556033759
- Create 2 tracks, each with mix1 and mix2 on - Send output of mix1 to bus x - Select input of mix2 to bus x - Use "I" button (input monitor) on mix2 to compare 2 mixes in real time. Or, as an alternative, put mix2 track into record ready and use "alt-k" to flick between 2 mixes. This probably sounds like a faff, bit it isn't really, especially if you have a RTD track in input anyway. I'm always comparing the mix I have now with where I was say, an hour ago, or last night, or last week, or last year. (Etc) |
Re: A/B Two Tracks
I have a print track set up in my template and I do use this quite a bit with the Input selector, but I mostly use the X-Or option on Solo to A/B between two stereo mixes. However, the Shift M is really what I was looking for. In this situation I was not comparing two mixes. I had a duplicate vocal on another track. One vocal had some tuning corrections and processing slightly different from the other vocal track. I wanted to A/B them within the context of the other tracks.
Re: A/B Two Tracks
Is Nugen's AB Assist still free for Pro Tools users?
Re: A/B Two Tracks
No audio in frozen tracks after export selected tracks to new session | PierrevC | Pro Tools 2018 | 4 | 11-14-2018 03:33 PM |
OPEN WITH TRACKS INACTIVE???---snow leopard is biting my foot (& tracks) | stormmusic | Post - Surround - Video | 2 | 10-09-2009 04:43 PM |
Instrument tracks VS Aux tracks+MIDI tracks | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2006 04:08 PM |
How many Megs does a 4 minute song with maybe 3 stereo tracks/13 mono tracks take up? | Sergeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-04-2002 02:31 PM |
Would the Line 6 POD pro SPDIF outs make the guit. tracks MIDI tracks? | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2000 08:40 AM |
