Issues installing pt 8 le on windows 7
I need lil help please. I just installed pt le 8.4 cs2 on my desktop. after the whole thing went throught the setup i try to run the program and i get a series of theses type of messages.
Could not complete your request because ACCESS violation occuredunable to read location:0x00000040 at address: 0x62122b39 in moduleAE.dll. Does anyone know the reasona for this and how to fix it?? thank you |
Re: Issues installing pt 8 le on windows 7
http://duc.avid.com/showthread.php?t=193636 |
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
this is may sandra
SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : ALPHAMATRIX User : ALPHA MATRIX Processor Model : AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ Speed : 2.51GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 2x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size Computer Platform Compliance : AMD LIVE! Mainboard : Asus M2N-SLI DELUXE BIOS : Phoenix Technologies, LTD ASUS M2N-SLI DELUXE ACPI BIOS Revision 0404 08/21/2006 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DIMM DDR2 Chipset Model : AMD Athlon 64 / Opteron HT Hub Front Side Bus Speed : 2x 1GHz (2GHz) Total Memory : 4GB DIMM DDR2 Channels : 1 Memory Bus Speed : 2x 359MHz (718MHz) Memory Module(s) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : ATI Radeon HD 4350 (SM4.1 600MHz, 512MB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor STREAM Processor : ATI Radeon HD 4350 () Storage Devices Hitachi HDS722516VLSA80 (164.7GB, SATA150, 3.5", 7200rpm, 8MB Cache) : 153GB (E:) Hitachi HDS725050KLA360 (500.1GB, SATA150, 3.5", 7200rpm, NCQ, 15MB Cache) : 466GB (C:) Maxtor 6Y160M0 (164GB, SATA, 3.5", 7200rpm, NCQ, 8MB Cache) : 153GB (D:) Maxtor 6Y160P0 (164GB, USB, 3.5", 7200rpm, 8MB Cache) : 153GB (I:) TSSTcorpCD/DVDW SH-S182M (ATA33, DVD+-RW, CD-RW, 2MB Cache) : 7GB (F:) Logical Storage Devices Hard Disk (C:) : 466GB (NTFS) @ Hitachi HDS725050KLA360 (500.1GB, SATA150, 3.5", 7200rpm, NCQ, 15MB Cache) MATRIX GOLD (D:) : 128GB (NTFS) @ Maxtor 6Y160M0 (164GB, SATA, 3.5", 7200rpm, NCQ, 8MB Cache) Hard Disk (I:) : N/A @ Maxtor 6Y160P0 (164GB, USB, 3.5", 7200rpm, 8MB Cache) MATRIX PLAT (E:) : 153GB (NTFS) @ Hitachi HDS722516VLSA80 (164.7GB, SATA150, 3.5", 7200rpm, 8MB Cache) 3.5" 1.44MB (A:) : N/A Pro Tools LE (F:) : 7GB (CDFS) @ TSSTcorpCD/DVDW SH-S182M (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS MCP55 LPC Bridge LPC Legacy Controller 1 : ITE IT8716F Audio Device : ASUS MCP55 High Definition Audio Audio Codec : Analog Devices AD1988B Sound Chip Audio Device : VIA M Audio Audiophile Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS MCP55 IDE Disk Controller : ASUS MCP55 SATA Controller Disk Controller : ASUS MCP55 SATA Controller Disk Controller : ASUS MCP55 SATA Controller Disk Controller : ASUS P5B [JMB363] USB Controller 1 : ASUS MCP55 USB Controller USB Controller 2 : ASUS MCP55 USB Controller FireWire/1394 Controller 1 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Send To Microsoft OneNote Driver (300x300, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Deskjet F2100 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : NVIDIA nForce Networking Controller Network Adapter : NVIDIA nForce Networking Controller #2 Wireless Adapter 1 : Broadcom 802.11g Network Adapter (802.11g (ERP), AES-CCMP, 412.32Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 3.7 Performance Enhancing Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Am I correct in assuming that the M-Audio Audiophile is your chosen Pro Tools interface?
If so... PTLE is not compatible. You need Pro Tools M-Powered 8, or Pro Tools 9. If that is not the case... did you follow the instructions as suggested by Quikdraw? What is the LE interface you are using?
Issues installing protools LE 8 on Windows XP SP2 | dannyt18 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-27-2011 01:17 PM |
issues with installing digi 003 | jam2323 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-28-2009 02:22 PM |
Issues installing... | mcutt | Pro Tools M-Powered (Mac) | 1 | 03-14-2008 01:25 PM |
Issues Installing Xpand! | modern_drummer85 | Virtual Instruments | 1 | 10-22-2007 04:02 PM |
Issues after installing UAD-1 | Concious Burning | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-05-2005 12:17 PM |
