Distorted input after velocity edit
Hi there,
I'm having a strange problem! No idea how to fix it. The problem is that say for example, when I enter the tuner (good old clean setting) the guitar is quite heavily distorted. This has affected all of my tones. This happened immediately after I increased the velocity on multiple keys in the midi sequencer. I can only assume this is no coincidence. I tried doing the exact opposite of what I just did but It looks like I am stuck with the problem. Even if I remove the eleven from my computer its the same :/. I don't know how to put this any better but that's it. Its like the entry level input on the eleven rack has been upped? |
Re: Distorted input after velocity edit
Hmm, sounds odd.
If you look at the input meters on the Eleven Rack does it show you are clipping? Press EDIT/BACK scroll to Meters And adjust the knob so it is showing the meters for Gtr(L)+Mic(R)
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Nah no clipping :/ at the moment, only a quarter of the bar.
I've also had a problem with another midi controller where when I was scrolling through the different presets, the eleven rack would jump to another guitar preset, so I'm aware these types of issues can occur somehow. Pretty confusing this one though. I have no idea where I would control the level of whatever signal the tuner uses. I am assuming just the completely dry input signal.
I actually checked the output meter there sorry. The one you said is very very low. Only like 1/20th of the bar when i do a hard hit of the strings.
Hmmm I did a factory reset and problem persists :/
Maybe a problem with low battery on EMG's? I'll get a new one and post if that works. |
Okay my bad! That was indeed the problem.
Can't edit velocity only anymore? Notes copying with velocity data... | kingtinker | Pro Tools 10 | 5 | 11-12-2011 10:53 AM |
Midi edit, a way to raise velocity on hits | aehn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-26-2010 09:47 AM |
simultaneously edit velocity for multiple copies of an event? | bms9nmh | MIDI | 3 | 05-01-2009 04:43 PM |
New to PLTE and MIDI - Q re velocity on the edit page | blast9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-08-2008 03:13 AM |
Change Velocity input level in PT | stringster | MIDI | 2 | 08-01-2006 12:57 PM |
