sample rate stuck on 44.1 on my 1814...HELP ME PLz
hey everyone
I tried to search for this but couldnt find anything of use. basically my problem is that when i start up my PTMP session i have only one sample rate to choose from. 44.1. and if i try to open a previous session which used 48K it tells me that this sample rate is unsupported by the current playback engine. i had a real gewd go to try to nose around and change some things which i thought might affect it but i havnt been able to get it to use anything other than 44.1!!! heres what i tried (in a nutshell) i reinstalled PTMP and my 1814 drivers made sure that the built in speakers/audio was not interfering(i have not installed the drivers on this partition) ummm what else, i cant remember off the top of my head (i didnt document it) but i tried some other things as well. Please help Ludi |
Re: sample rate stuck on 44.1 on my 1814...HELP ME PLz
Well, i called DIGI tech support, they told me that they dont support PTMP, they directed me to an EMAIL adress, from which i have recieved no response...
i think they should take some of the funds from the advertising and inject just a little bit into some half decent tech support. its just a real pain in the neck, when u have PAID WORK waiting, and you cant do a thing about it because there is little to no tech support available. Dissapointed Ludi |
ok just got a response...
hasnt fixed my problem yet but the ball seems to be rolling... Ludi |
hey i had this problem too a while ago!!!...it started when i downloaded and installed that new driver update for m-audio 1814...so i just uninstalled everything and and installed the original driver i've got when i bought my 1814 and that fixed it.just try totally removing evrything that has anything to do with m-audio 1814 on ur DAW and start from scratch.
Pro Tools 11.2 Pro Tools 10.3.9 REAPER MPTK2 ProFire 2626 Benchmark DAC1 Neumann KH 120 A Avid Artist Mix ASUS Sabertooth Z77, Intel i7-3770K CPU OC'[email protected], 32 Gigs RAM Mac OS X 10.9.3 Mavericks |
hey thanx man
did you uninstall all of your plugins too? or just like PTMP and 1814 driver? thanx for the words Ludi |
nah i didn't uninstall my plugins...i just re installed PTMP and the original 1814 drivers...its annoying that m-audio gives you driver upgrades that screws up ur perfectly functioning system. that's why i don't upgrade my drivers unless i really need to...like if pro Tools would start telling u to install new drivers...i've already installed PTMP7 and its running perfectly with my original drivers and yet its written on the M-powered site that u need new drivers to run M-powered7 software...hehe! if it aint broken then y fix it...anyweyz hope u got ur system up and running as it should be...
thanx man... im goin to get right on it when all my hectic exams are over... damn tafe
Ludi |
Stuck Sample Rate | Cowboy Bob | Eleven Rack | 3 | 12-05-2013 06:33 AM |
Sample rate greyed out and stuck on 44.1 kHz | pzykt | macOS | 1 | 06-01-2013 04:30 AM |
Sample Rate stuck at 96k? | Djehuti | Pro Tools TDM Systems (Mac) | 4 | 10-08-2012 01:33 PM |
1814 ERROR MESSAGE WORD CLOCK OR SAMPLE RATE | alienmusician | Pro Tools M-Powered (Win) | 0 | 06-10-2006 01:51 AM |
5.3 problem--stuck sample rate pop-up | Captain Crunch | Pro Tools TDM Systems (Mac) | 2 | 02-14-2002 09:39 PM |
