Compatibility between Dynamics II and Dynamics III
I am using Pro Tools 9 HD system. I got the old session from others. There are few channels apply Dynamics II plug-in (Compressor II) and other channels apply Dynamics III plug-in (EQ III) in the session They say they can read both plug-ins but Pro Tools 9 cannot read Dynamics II. I checked the session with Pro Tools 7 but it cannot read Dynamics III. (read only Dynamics II) My question is, - Is it possible to read two versions of Dynamics Plugin simultaneously? - If it is possible, I would like to know how to read Dynamics II with Pro Tools 9. ProTools HD 9.0.6 Mac OS X 10.6.8 192 I/O Blueface Can anyone help me to solve this problem? Last edited by sjtae; 07-25-2016 at 10:12 PM. |
Re: Compatibility between Dynamics II and Dynamics III
It's been a while, but if I remember correctly, it was around PT6.9 / PT7 that EQIII was introduced.
I think DynamicsIII was a little later, which would explain why your installation of PT7 does not load the plug-in (but I could be remembering this incorrectly, with both EQ & Dynamics vIII arriving together, and D-Verb getting the later overhaul???). Anyway, when the vIII versions were introduced, the old vII versions were moved to : Mac = Macintosh HD/Library/Application Support/Digidesign/Plug-Ins (Unused) or Windows = C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused) So, in order to be able to use both versions simultaneously, you need to move the old vII versions back to the regular plug-in folder, before you launch Pro Tools : Mac = Macintosh HD/Library/Application Support/Digidesign/Plug-Ins or Windows = C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins I honestly can't remember if it's possible to save the current settings of the vII plug-in as a preset, and then import it in to the vIII version and save it (for sake of compatibility, moving forward with 64bit versions of Pro Tools, that use the AAX format), so you may have to open both vII & vIII versions of the EQ and Dynamics plug-ins, an manually copy & paste each value individually. However, the good news is that you can have both vII & vIII 32bit RTAS plug-ins installed, and running simultaneously - so your session should open, and run as intended. But it would be prudent, as I mentioned above, to transfer the settings from vII to vIII, if you ever want to open these sessions in a newer version of PT, as there will never be version of the vII plug-ins that are compatible with 64bit AAX systems. |
Thanks for the answer! :)
I have already moved the plugins to the Folder but it does not work, just shows alert message.. I cannot even try the second solution cuz the plug-in is inactive so I cannot see any setting of the plug-in. If you know any other reason or solution, please let me know. |
Sorry to break the bad news: seems 7.3 with a different OS can do it.
The reason - with some yester-links to clarify: Pro Tools Software Versions Below 8.0.3 Are Not Compatible With Snow Leopard. http://avid.force.com/pkb/articles/e...ility/en353275 DigiRack Plug-Ins Guide v6.4 http://akarchive.digidesign.com/supp..._Guide_6.4.pdf Includes EQ II and Dynamics II Pro Tools HD 7.3 Technical Documents – All http://avid.force.com/pkb/articles/e...guide/en358325 DigiRack Plug-Ins Guide v7.3 http://akmedia.digidesign.com/suppor..._v73_32959.pdf Includes EQ II & EQ III and Dynamics II & Dynamics III DigiRack Plug-Ins Guide v8.0 http://akmedia.digidesign.com/suppor..._v80_56080.pdf Includes EQ III and Dynamics III Avid Audio Plug-Ins Guide Version 9.0 http://akmedia.digidesign.com/suppor..._v90_69827.pdf Includes EQ III and Dynamics III
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
no problem with dynamics in pt 8 problem with rane series dynamics at pt 8 | vageli | Pro Tools TDM Systems (Win) | 0 | 01-25-2011 10:00 AM |
Can Dynamics 2 and EQ 2 coexist with Dynamics 3 and EQ 3? | noharmlessrock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-29-2008 11:23 AM |
Expander Gate/Dynamics III vs Drawmer Dynamics | DaveSB | Pro Tools TDM Systems (Mac) | 14 | 01-31-2007 05:26 AM |
Dynamics III is available! :) | vocalvoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 11-08-2005 03:12 PM |
Dynamics III now available | Vaphoron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-08-2005 11:25 AM |
