  #71
Old 03-05-2016, 04:36 PM
Mirzar Mirzar is offline
Default Re: "SystemId Entered does not match the SystemId on record for this Serial"
Hello!
I'm new one on this forum, and I like to say Hello to Everyone :)
Sorry for my english, it's not my first language.
I just bought the Expansion Pack , try to install , and got the same problem.
"SystemId **** Entered does not match the SystemId on record for this Serial Number ****"
For information, Win 7 64 , no IE on system.
Please , I need help.
Regards
Mirek
I'm wondering.. why can't Avid do anything with this issue.
As I can see, it's happen all the time..
  #72
Old 03-07-2016, 12:06 AM
jeffro's Avatar
jeffro jeffro is offline
Welcome to the community.
Answered your support case so please check your email and reply to that with your results.
linkedin
  #73
Old 03-07-2016, 03:05 PM
Hello
Problem solved :)
Thank you very much :)
Regards
  #74
Old 05-08-2016, 10:58 AM
Krysh Krysh is offline
Hello,
Same story, just bought an eleven rack with firmware 1.00.3, got the Expansion Pack but cannot update.
I'm an a mac with OS X 10.11.4.
I got the "cannot activate" issue but resolved it by creating the missing folder.
But now I have the Systemid mismatch with Serial Number.
I just created a case about this, if a support staff can have a look to send me valid credentials.
Thanks !! :)
  #75
Old 05-09-2016, 11:51 AM
jeffro's Avatar
Originally Posted by Krysh View Post
...just bought an eleven rack with firmware 1.00.3, got the Expansion Pack but cannot update...
Looks like Corina was able to solve this via your support case.
linkedin
  #76
Old 05-09-2016, 12:28 PM
Quick update : had an answer from the support less than 24h after I submited my problem, with a new activation code and it worked !
Good job on the support ! (But still, the buying process needs to be audited...)
Indeed :)
  #77
Old 07-09-2016, 03:02 AM
Knudsen Knudsen is offline
Default "SystemId Entered does not match the SystemId on record for this Serial"
Hi!
I´ve bought a used Eleven Rack (without any Registration Card). I´ve updated the Firmware to 1.00.3 and install the Software Version 1.2.9.
So far so good. Today, I bought the Expansion Pack today and have the same problem:
I have allready open a Support Case and recieve a Case number via eMail. There are many User´s wich get no answer from the support (i read that several times on my research) and that´s why i post here.
I´m working on a iMac with OS X 10.11.5 and the Workaround to create the needed folders in the libary doesn´t solve the problem.
Help...I need somebody
Greetings
  #78
Old 07-09-2016, 08:41 AM
Benoni's Avatar
Benoni Benoni is offline
Originally Posted by Knudsen View Post
Hi!
Greetings
I will escalate this, but you have already done all the correct steps. Support will get back to you with a new set of codes or reset your current codes.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #79
Old 07-10-2016, 04:20 AM
Thanks man!!
  #80
Old 07-11-2016, 04:42 AM
The support send me a new serial number and that fixed the problem!
Now i'm happy! 😎
Expansion Pack - SystemID? jimst57 Eleven Rack 6 03-22-2011 01:12 PM
*The serial number you entered has already been registered.????? ElQueso Pro Tools M-Powered (Win) 3 05-14-2010 09:35 AM
The serial number you entered has already been registered.?? joerusi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2008 07:08 AM
