Old 09-19-2012, 10:07 AM
10willy 10willy is offline
Post Custom Note Duration
I am Running Pro-Tools M-powered version 9.05, windows 7 64 bit. I cannot locate the "custom note duration" while working with the midi keyboard. I was always able to select this from the drop down menu by clicking and holding the pencil tool in Pro Tools 8. Has there been a change that I am unaware of???
10willy
Old 09-21-2012, 12:54 PM
daeron80 daeron80 is offline
Default Re: Custom Note Duration
I was hoping somebody would answer this authoritatively. I never used v8 - went straight from 7.3 to 9, so I can't comment on what it did in 8. All I know for sure is, the term "Custom Note Duration" occurs in the v8 and 9 Reference Guides only once (each), and that's in the Index at the end. There's one item under it (indented) called Follow Grid, which is about Default Note Duration. I'm not sure how Follow Grid is understood to be a kind of Custom Note Duration, nor how Default is equivalent to Custom. Maybe they removed that feature at some point for whatever confounding reason and left only that little virtual paper trail as a vestige in memorium.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
How do u extend Midi note duration in PT9? Metallicamasta Pro Tools 9 5 06-23-2011 09:01 AM
PT8 Score Editor - change note duration sladlow Pro Tools M-Powered (Mac) 15 08-16-2010 05:31 PM
Custom note duration 10willy Pro Tools M-Powered (Win) 2 06-04-2010 01:35 PM
Changing the midi note duration rbon MIDI 5 05-13-2008 03:11 AM
Changing MIDI Note Duration - Need Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-20-2007 09:47 AM
