Pro Tools + 61-note MIDI Keyboard = missing low notes!
Hi there,
I could really use some help with the following problem: I have Pro Tools 8 LE, Steven Slate Drums plug-in, and a MIDI Casio keyboard with 61 keys. Since the keyboard has 61 instead of 76 keys, it starts on note "C1". Steven Slate Drums maps its drums to lower keys (ex. B0 is double kick). These assignments can NOT be remapped; I can't play the drums assigned below C1 since my keyboard starts at C1! I don't have an octave changer on my keyboard; instead I have "Transpose", which lets me move the key up/down a few notes. I tried but it does nothing for the drums (i.e. C1 still plays what C1 was originally assigned). Sooo....is there anyway (in Pro Tools?) to reassign my MIDI keys? It would be perfect if I could move my keyboard down an octave (C1 key --> C0)...heck, even down one note would work since I really need B0! Thanks in advance! |
Re: Pro Tools + 61-note MIDI Keyboard = missing low notes!
oh, just to add that I can play the low notes (like B0) in Pro Tool's MIDI Editor.
However, mouse clicking the virtual keyboard does not allow for Touch Response, so everything is the same loud volume. I'd much rather play everything on my Casio keyboard! |
WHat you might try, though, is using the MIDI real time properties feature in Pro Tools. I assume you have SS drums instantiated on an instrument track. Record enable it. ON the MIDI menu, (right click somewhere in the instrument track) use the TRanspose feature on the MIDI real time properties screen, and transpose down 1 octave. That should have the effect of transposing your C1 to C0 on input. Good luck.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Did you not see my post about using the MIDI real time properties function? I think that'll do the trick for you.
I have a Casio CTK-530 (I've had it for ages), 61 keys, connected via MIDISport Uno to my PC's USB port. And yes, there is a Transpose button that lets me move it down a couple keys in "real life". However, every time I control a virtual instrument with my keyboard, it still starts from C1, so I don't think I'm transposing the MIDI output... As for your 2nd advice, yes I have it as an Instrument track. I tried something like what you suggested but it was after recording the MIDI (which turned out useless since I need the octave change while I record). I'll definetly give it a shot! |
Awesome, that sounds like the fix! I wish I could test it out right now, but I'm at work...
Here's what I tried: Intrument Track --> Record Enabled --> MIDI Real-Time Properties --> Transpose by Oct -1 --> Write to Track ---> Record C1 still plays C1 on my Casio. I suspect the "Write to Track" button in MIDI Real-Time Properties only changes the octave in the MIDI Editor. |
Drawn MIDI note length only staccato notes, regardless of note length | kingofallwookies | Pro Tools 11 | 2 | 02-07-2014 07:10 AM |
Pro tools 10.1 Midi plays keyboard note with same intensity when I dont want it to | shamanrock | Windows | 3 | 02-22-2012 08:44 PM |
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
Pro Tools + SSD + 61-note MIDI Keyboard = missing low notes! | k0000 | The Drum Room | 9 | 03-04-2011 09:19 PM |
Pro Tools 8 + 61-note MIDI Keyboard = key change? | k0000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-04-2011 08:43 PM |
