Old 04-25-2007, 11:52 AM
black030 black030 is offline
Default 5300 series in a xw8400? Does it work with PT?
Has anybody successfully tried one of the Intel Xeon 5300 Quad-core series processors in a HP xw8400 workstation? The official compato list only advises to use 5100 series processors with PT 7.3 (HD3).
I tried, a while ago, a 5355 in a DIY PT computer project, which wasn't compatible at all (had to return it), but I doubt that the cpu was the weak link in that system. (The playback engine showed 4 processors for RTAS.)
PT 7.3.1cs2
TDM HD3 PCI
HP xw8400
192 i/o
Old 05-01-2007, 11:48 AM
Default Re: 5300 series in a xw8400? Does it work with PT?
Nobody?
I understand: The risk of jeopardizing a perfectly working system with a cpu that is still expensive and maybe is incompatible, is really high and not really woth it?!
PT 7.3.1cs2
TDM HD3 PCI
HP xw8400
192 i/o
Old 05-01-2007, 12:11 PM
MDog MDog is offline
If you can find a place with a good return policy, why not give it a shot? Then come back and let the rest of us know how it worked
My best friend is a pitbull.
http://www.badrap.org
Old 05-01-2007, 05:16 PM
You first
PT 7.3.1cs2
TDM HD3 PCI
HP xw8400
192 i/o
Old 05-01-2007, 06:36 PM
If I had an HP XW8400 and found a store that would guarantee a return if it didn't work, I wouldn't have any problems at least trying it. What do you have to lose? If it turns out to be unstable just return the new processor and replace with the original.
I know next to nothing about a HP XW8400, and I assume you're saying that the processor is compatible with that MB. If not, you should contact HP and find out if that processor is compatible. I highly recommend *not* installing that CPU unless you're absolutely certain it's compatible. Nothing like failing the "smoke test" when firing it up.
If your only question whether Pro Tools will work with it, odds are that Digidesigns compatibility page is just out of date.
Old 05-02-2007, 03:42 AM
The compatibillity with the xw8400 is out of the question - that works!
My interest is merely if PT is compatible or not with a 5300
PT 7.3.1cs2
TDM HD3 PCI
HP xw8400
192 i/o
Old 05-02-2007, 12:11 PM
What's the issue then? What's the worse that will happen?
Old 05-02-2007, 12:57 PM
Are you using a HP xw8400?
PT 7.3.1cs2
TDM HD3 PCI
HP xw8400
192 i/o
Old 05-02-2007, 04:01 PM
Here's from an earlier post: "If I had an HP XW8400 and found a store that would guarantee a return if it didn't work, I wouldn't have any problems at least trying it. What do you have to lose? If it turns out to be unstable just return the new processor and replace with the original."
I've built my last two TDM machines. The first was an Asus P4C800-E, and I just finished upgrading to a Tyan Tiger K8WE Quad core. Surely upgrading the CPU on your HP is as easy as either of those two MBs. It would be about a ten minute job on either of those computers.
I'm just curious as to why it's much of an issue. Sorry if I'm out of line here. Good luck!
Old 05-04-2007, 03:57 AM
Eugene Eugene is offline
Doesn't replacement of CPU's breake the warranty?
HP XW8400 vsukpadman Pro Tools TDM Systems (Win) 6 03-13-2017 10:43 AM
artist series mixer wont work battledog Artist Series 2 08-14-2012 03:14 AM
None of my artist series controllers work now trock Artist Series 4 11-18-2011 12:59 PM
Protools 3.4 & Powerbook 5300 [what comdination of DAE&INIT to use ?] Please help valentineval Pro Tools TDM Systems (Mac) 0 01-04-2000 01:34 PM
powerbook 5300 and my protools 3.4. Will it work. Please help valentineval Pro Tools TDM Systems (Mac) 1 12-27-1999 07:10 PM
