monitor ringing from my G4 MDD
I have this feed back problem ( or an audible sine wave ) when I dont use my 2 track devices
I have my G4 on a seperate surge protector but on the same circuit , should I use a ground lift on my g4 ? Or is that a bad idea should I plug it into a differetn circuit ? when I turn my g4 off it goes away so I figure its not a console power amp monitor issue but my g4 tower Im a little reluctant to ground lift it but will if some one knows that wont cause any harm / damage thank you sincerely |
Re: monitor ringing from my G4 MDD
the wierdest thing is when I hit 2 track monitor on my board the ringing stops
I am perplexed |
I think it might be my 001 causing the feedback ringing anyone else have this problem
mI mthink this because my MIA echo sound card is one of my 2 tracks in and does not have this effect Im going to hook my 001 into the 2 track 2 and see if the ringing is there |
I just installed a different sound card for cubase would these cause such a problem ......anyone ?
bump bump bump
Ringing behind the bridge | BobbyDazzler | Eleven Rack | 6 | 05-12-2012 07:27 AM |
Help with Ringing Mic | Earl D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-16-2011 02:03 PM |
Ringing in Ears | gdugan | Pro Tools TDM Systems (Mac) | 27 | 05-23-2008 02:45 PM |
Odd Ringing? Help... | Rip17 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-15-2005 07:58 PM |
M Box Ringing Noise | MoLa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-20-2005 03:00 PM |
