Old 07-18-2018, 04:23 PM
santoorman santoorman is offline
Default midi notes disappearing when moving to clip boundary
why does my midi note disappear when i try to move it to beginning of clip that's aligned to bar? i have grid mode on and I double checked that the region starts right at the bar... seems to me it's trying to align to bar and region/clip doesn't go there so that's why i disappears but that's not the case...
also tried it in Notes view in the edit window, did same thing...?
btw I have copies of the regions so don't want to consolidate...
here is video of what's happening:
https://www.dropbox.com/s/54mq25wib6...1-49.mp4?raw=1
thank you
Old 07-20-2018, 12:19 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: midi notes disappearing when moving to clip boundary
Having the same issue here. Doesn’t happen all the time, but when it first happens it’s consistent. It goes away when I restart Windows, but does return again after a while.
Untill this bug is fixed my workaround is to move the note in steps with the keyboard rather than using the mouse.
The note dissapares when its moved on or close to the start of the region border.
Old 07-24-2018, 02:50 PM
risey's Avatar
risey risey is offline
This problem has been going on for a while, sometimes u can get away with it by selecting CLIP before NOTES, then select the area where the notes wont draw and delete, even if there is nothing there, dont ask me why, but sometimes that works...
http://www.PhatMonkey.me
Windows 10 64bit | Asus Rog Hero Xi | Intel i9-9900K | Corsair LPX Vengeance 64g DDR4 RAM | Avid Mbox Pro 3 | Focusrite 18i20 2nd Gen | MSI RTX 2080TI Gaming X Trio | Acer Z35 Predator Monitor
Old 07-24-2018, 02:59 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
I've run into this as well. I work around it by consolidating the clips, though this is obviously annoying. This and the lack of proper MIDI playlists makes PT MIDI still feel like a tacked-on afterthought compared to other DAWs.
Old 07-24-2018, 10:17 PM
thanks for the replies. bummer this doesn't work. best to stick to what PT is best at, recording and edit audio and mastering... i also have so many issues with the score editor!!
Old 07-26-2018, 11:50 AM
foxes's Avatar
foxes foxes is offline
I've been having this very issue since PT 12........very annoying
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
Old 07-26-2018, 01:21 PM
Sardi Sardi is offline
Got this for the first time a couple of days ago. Thought I was going crazy.
Had to add a bar to the start of the clip, move the note, then trim the excess bar off the clip.
Hmmmmm...
Old 08-13-2021, 11:04 AM
Noemie Noemie is offline
Thanks Risey,
as esoteric as it might seem, your workaround worked for me.
The joke is that my problem was slightly different as the note appeared visually but didn't play.
I've had to move the note, select and erase the empty area and replace the note.
Digidesign, you definitely have a lot of work to rivalise with all the other DAWs which can manage a brand new revolutionary language : MIDI
Old 08-13-2021, 12:15 PM
rinky rinky is offline
Originally Posted by Noemie View Post
Thanks Risey,
I wish Digidesign was still in control. Ha!
You probably meant AVID.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
Old 08-14-2021, 03:11 AM
Yes it's true, I hadn't used Pro Tools since the brand change and now I'm coming back, it feels like some crazy people have been messing in my home... So sad
Disappearing MIDI notes PhilSchroeder Pro Tools 12 0 02-15-2016 09:57 AM
Disappearing MIDI notes in regions???? MdotCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-28-2009 12:47 PM
MIDI Notes Disappearing in PT LE 6.3 olivix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-27-2007 05:33 AM
Digi: Disappearing Midi Notes is a *bug* cakes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-27-2006 05:25 AM
Disappearing Midi Notes zombie69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2006 09:27 AM
