Old 02-07-2006, 12:03 PM
Aquarius Aquarius is offline
Default Rail, please help ! Mp3 bounce wrong !!!
Hi Rail,
I've experienced a real weirdness today when I tried to bounce some audio loop to .mp3.
Here's what happened :
I've made an audio loop (20sec of amb) for a video game : when I hit play, it loops perfectly.
The session is 48khz, 24bit, delay compensation on, but the files have to be delivered in .mp3 (128/44.1Khz) ;
When importing back the bounce into the session, I've noticed around 1200 samples of blank or "quasi-fade" at the beginning of the audio region !
I've checked with a .wav bounce of the same region, imported it into my session : the problem has disappeared !!!
I've also tried to use iTunes to export the .wav bounce to .mp3 with the same result : a quasi-fade at the beginning
I don't know what it could be...tried other sample rates with no success...
Here's my setup :
G4 2X1.33
Os X.4.2
1,25g ram
PT 6.9.3cs2
QT 7.0.3 Pro
Itunes 6.0.1
What do you think ?
Best regards,
Olivier
Old 02-07-2006, 01:31 PM
axiom axiom is offline
Default Re: Rail, please help ! Mp3 bounce wrong !!!
I'm not Rail but I can tell you, in my experience, using .mp3 for seamless loops is next to impossible. I have done a lot of game audio and have never been able to make it work right.
For some reason there is always some sort of hiccup introduced in the conversion process to .mp3 so there will always be a pause or glitch when it loops.
EDIT: Just so you know, this isn't a ProTools issue. No matter which application you use for conversion you will always get the silence at the beginning of the .mp3 file.
Will Loconto
www.WillLoconto.com
Old 02-07-2006, 01:39 PM
clusterer clusterer is offline
Hi Rail,
Here's my setup :
G4 2X1.33
Os X.4.2
1,25g ram
PT 6.9.3cs2
QT 7.0.3 Pro
Itunes 6.0.1
What do you think ?
Best regards,
Olivier
perhaps you can convert .aiff-files to mp3´s with itunes....
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 02-07-2006, 02:36 PM
Thanks guys !
That answers my question, but what would you do if there isn't enough space for the project on a CD and they won't release it on DVD ?
There has to be a way to loop mp3's of some sort....
Best,
A.
Old 02-07-2006, 03:53 PM
You can look into using the .ogg format. You can loop that and it has great a compression ratio. They just have to be able to play it back in the game.
Will Loconto
www.WillLoconto.com
Old 02-07-2006, 05:35 PM
minister's Avatar
minister minister is offline
would wave files do?
20 sec's of a mono wav at 16/44 is 1.68MB
20 sec's of a stereo wav at 16/44 is 3.368MB
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Wrong file is being played and waveform is wrong jmullins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-30-2010 01:29 AM
MP3 Bounce creates wrong sample rate rockcreek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-29-2009 09:40 AM
THANKS, RAIL! Idahoguide 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-06-2006 06:41 PM
Bounce is in the wrong pitch Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2005 01:45 PM
Rail, you da man! guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-10-2004 12:33 AM
