Old 02-21-2017, 06:11 AM
michaelfbates michaelfbates is offline
Default AAF vs EdiLoad and conforming from rushes
I'm thinking about getting EdiLoad to start doing dialogue builds from EDLs rather than trying to get working AAFs with all the production sound metadata still intact.
I would say that on 90% of jobs I have issues with AAF turnovers and often quite a bit of back and forth to get what I need from picture departments and I still don't always get AAFs that have all the scene / take / channel name metadata intact in the production sound.
So my questions are:
Is getting an EDL which works in EdiLoad easy?
Do you have to be very specific with what you request or will any EDL that contains all location audio tracks work? (I know about the 4 track limit in EDLs so am anticipating having to ask for more than one EDL.)
Does it still work when dealing with production sound that has had some or all of its metadata damaged or stripped? E.G. when projects come through Premiere.
I also really like the look of the scene change and picture cut tracks features in EdiLoad, would love to get that task automated, especially for feature work. Would be good to know if that's a reliable feature and if it requires any specific requests when asking for EDLs.
Thanks for your help!
PT Ultimate 2021.3 | macOS 10.15.7 | Mac Pro 7,1
michaelfbates.com
imdb.com/name/nm4876413
Old 02-21-2017, 02:41 PM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default Re: AAF vs EdiLoad and conforming from rushes
Too many picture editors these days have ever done a 3 machine online and do not speak EDL. But don't let that stop you trying.
When you find co-operative assistants it can be a joy.
I would never mix a drama without scene change tracks, even if I have to do it manually.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 02-22-2017, 02:07 AM
Yes, I can well imagine! Do you find yourself using EDLs and EdiLoad or are you getting decent AAFs and working from them?
Yep, I already do scene change tracks manually, just interested to hear if EdiLoad actually manages to automate it reliably.
michaelfbates.com
Old 02-22-2017, 02:58 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Hi Michael,
Thanks for checking out EdiLoad
It should be, but this depends on your editor or assistant editor
It's best to give them the EDL spec shown in the EdiLoad user guide. At the very least you need them to export an EDL that contains the correct rollname (links to the WAV file Sound Roll metadata), de-select the creation of B-Rolls (usually defaults to on), and possibly export the WAV filenames in the comments if the roll names aren't valid or your WAVs don't contain metadata.
This limitation only applies to certain EDL formats like CMX3600. File32 can contain more than 24 tracks.
If the WAVs don't contain metadata (or specifically a Sound Rollname) then you rely on the picture edit system to be able to export the WAV file names in an EDL. I've seen EDLs from Premiere where they contain valid Roll Names that link to the Sound Roll metadata contained in the WAVs.
For more information on conforms (assembling WAV files) with EdiLoad and Pro Tools, see the videos in the following two blog posts:
Conforming (assembling) Location WAV Files with EdiLoad and Pro Tools
Customising an Edit List to Conform location WAV files using EdiLoad
This requires a picture EDL (EDL containing the picture edits). Picture cut tracks can be generated by EdiLoad with any EDL that EdiLoad can import. All it's doing is converting the "Master" TC locations in the EDL into a PT session (or you can generate Markers in a MIDI file). Scene Change tracks require that the footage in the edit system has been logged with some kind of scene/slate information and can be exported in the clip name field of an EDL (this is generally why happens on a TV/Film drama production). You then setup EdiLoad to extract just the scene number from this clip name to recognise which shots (events in the EDL) relate to which scene, allowing you to create an event for each scene. You can then export a PT track or MIDI file containing markers for each scene change point.
Feel free to download EdiLoad and try it out for yourself. Simply click the 'Try' button when you first run it.
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 02-28-2017, 12:28 AM
JWalkerPostAudio JWalkerPostAudio is offline
I'm a big fan of EdiLoad. Getting useable EDL's has usually been no problem. Sometimes I have to clean up and/or transfer roll names between columns, but EdiLoad is pretty intuitive in that regard.
I've only run into one major situation where the I had metadata issues on the EDL and it was because an Adobe editor was using merged clips in their workflow, which was nesting the audio clips in what the EDL read as video clips. It took some convincing on my part, but I got the editor to rebuild his audio on the timeline which enabled the EDL export to include the metadata I needed.
One thing I like to do with the scene change track is add in scene descriptions and use the track for my EdiCue ADR exports. I'll copy/paste the descriptions from a continuity list if one exists or make a simplified version from opening the script in the session interface in EdiCue and send the scene list info to the clips in Pro Tools.
-Justin
Justin Walker
Old 03-01-2017, 01:05 AM
Mark, that's amazing, thank you so much for this reply! It's so helpful, I'm planning to test EdiLoad on my next show, really looking forward to using it.
michaelfbates.com
Old 03-01-2017, 01:06 AM
-Justin
Thanks Justin, this is really useful detail to know before I start asking for EDLs. Thank you!
michaelfbates.com
HTML code is On
Ediload sound conforming (Sound rushes) Soundburst Post - Surround - Video 2 01-29-2016 06:39 AM
link to the original sound rushes when editing in Media Composer guyfixsen Post - Surround - Video 2 04-24-2015 01:07 AM
EdiLoad v3 released mfranken Post - Surround - Video 2 03-09-2015 09:27 AM
Sounds In Sync releases EdiLoad version 2 mfranken Post - Surround - Video 0 04-20-2012 07:21 PM
Syncing multichannel rushes Peter Groom Pro Tools TDM Systems (Mac) 3 05-14-2010 12:31 PM
