PT12 and Mackie Universal Control track names scrambled, anyone?
Anyone successfully using Mackie Control Universal with Pro Tools 12?
I use my Alphatrack -also in HUI mode- and it works perfectly fine. Everytime I switch tracks, it consistently displays the correct track name (abbreviation) on the blue LCD screen, but with the Mackie Control Universal it's never the case, it works in banks of 8 tracks as expected in HUI mode, but always about half of them displays some weird text instead of track name abbreviation, sometimes the word "Auto", sometimes random characters, sometimes it appears blank, and when I switch to the next 8 tracks bank (or channel) it gets worse, some track names appear repeated, many of them blank, etc. But it's only track name that's affected because every other channel item seems to work fine, the fader, all buttons, and also transport funtions works as expected. HUI functionality is very limited, but at least I would like to be able to use it that way since Avid decided not to implement MCU communication support, which works so much better than HUI. Tried both MCU and MCU XT together and apart, same problem. In MCU mode they work perfectly fine in Cubase 9, and also in Logic Pro X 10.3 in it's proprietary Logic mode. It's a real drag because you have to check the computer display everytime to figure out which channels correspond to what on surface, it becomes pretty much unusable. I wonder if the same happens with older Mackie HUI, or the newer MCU PRO and XT. The systems I tried with same results are: Pro Tools 12.5 12.6 12.7 Mac mini server late 2012 on 10.11.6 and 10.12.0 up to 10.12.3 MacBook Pro Retina 15" late 2013 on 10.11.5 Mackie Control Universal and Extender, both with 2.1.2 firmware (also tried older 2.1.1 on both)
macOS Mojave | Avid Pro Tools Duet, Apogee Groove & Symphony I/O | Pro Tools Studio 2022 Sound Engineer | Non-Avid Employee Last edited by Cacov; 02-21-2017 at 02:31 PM. |
Re: PT12 and Mackie Universal Control track names scrambled, anyone?
Anyone willing to share their personal experience? I just want to know if it's me making a configuration mistake, which would be the best case scenario. If it's a known issue I guess I should give up trying. I have not found a single post anywhere on this particular matter. Thanks!
macOS Mojave | Avid Pro Tools Duet, Apogee Groove & Symphony I/O | Pro Tools Studio 2022 Sound Engineer | Non-Avid Employee |
Look Good here, it's abbreviate like : Lead Vox = LdVr but other like Drum are ok
Damn... Please let me know if you get some strange behaviour when you change to the next 8 track bank and so. Tnx!
25 tracks and still good going thru the bank
Thanks man, I finally isolated the problem: I have a malfunctioning MIDIBOX MATE 4x4 crappy interface, or (most probably) it is faulty by design. I connected the MCU thru the Focusrite Scarlett 18i8 MIDI port and the problem was gone. Its a pitty since I specially bought the MIDIBOX 4x4 for use with the MCU and MCU XT as more ports are required. It's virtually impossible to find another 4x4 interface at this moment here in Chile, I had to buy it from Aliexpress.
Mackie Control Universal Pro | 4times4mil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 11-18-2016 06:49 AM |
PT HDX and Mackie control universal pro | Da Boss | Pro Tools HDX & HD Native Systems (Mac) | 6 | 02-04-2014 05:10 PM |
mackie universal control and 6.4.1 | Filmusic | Digidesign Hardware & Software | 0 | 09-08-2010 06:51 PM |
Mackie Control Universal Pro.... | KMAN385 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-29-2008 11:56 PM |
Mackie Control Universal or Tascam 1082 for control surface? | anders | Pro Tools TDM Systems (Mac) | 5 | 05-28-2007 06:12 AM |
