Old 08-04-2013, 08:31 PM
DAS-Mike DAS-Mike is offline
Default Logic Pro X and HD 192 Hardware
I am sure that has has been discussed elsewhere... a lot! -- I've been off the DUC for a while. I just installed Logic Pro X today and was pleased to discover that I can use my HD2 Accel -- 192 hardware with it. Obviously, no TDM, but that's fine for my Logic workflow. Logic X is fully and only 64 bit (no 32 bit bridge anymore), so why can't PT 11 pass audio via the 192/HD core using core audio?
Old 08-14-2014, 08:13 AM
dellel dellel is offline
Default Re: Logic Pro X and HD 192 Hardware
I'm looking all over the place for how to access all the I/O from my accel card. Is this no possible? I can only use 8 channels of the hardware in Logic Pro X and that's with the Core Audio enabled. If I disable the "Core Audio" I can't seem to access any Dididesign HW I/O. Your thread is the most recent mention of using these together that I've seen.
Old 08-14-2014, 09:44 AM
nst7 nst7 is offline
The old HD systems were limited to 8 channels. The new HDX and HD Native systems remove this limitation.
Logic Pro 9.1 with TDM Hardware TornadoTed Pro Tools TDM Systems (Mac) 14 02-05-2023 02:25 PM
Logic Pro 7 with Mix system hardware? derF Pro Tools TDM Systems (Mac) 7 05-18-2006 09:32 AM
Logic with PT hardware gw sound Pro Tools TDM Systems (Mac) 23 09-15-2005 03:05 PM
Logic on HD Hardware K-Wolf Pro Tools TDM Systems (Mac) 4 12-30-2002 07:41 AM
Logic and PT hardware Lion Pro Tools TDM Systems (Mac) 1 12-15-1999 10:44 PM
