Running Reason & Kontakt Through Outboard Gear
How would I go about running a drum sequence from Reason or Kontakt, for example, though an outboard pre amp - like the Great River MP-1NV or Focusrite ISA 220 - then back into Pro Tools? Is something like this possible? Or - how could I run a final mix through outboard stuff? Thanks. ~Henry |
Re: Running Reason & Kontakt Through Outboard Gear
if your rewiring those into protools, set your audio out to a destination you choose on your digidesign hardware through protools. Plug the outboard audio gear into the same output, and choose an input. route the input you located back into a channel in protools. you will have a loop. just make sure you don't route the inputed signal back out to the same channel you sent or you will cause a feedback loop.
ProTools/ Outboard Gear/ Reason | DLinares | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-30-2006 08:02 PM |
ProTools/ Reason/ Outboard gear | DLinares | MIDI | 0 | 04-25-2006 12:28 PM |
Running Soft Synths Through Outboard Gear... | Orange Worker | Pro Tools TDM Systems (Win) | 0 | 06-11-2004 10:19 PM |
Running Soft Synths Through Outboard Gear... | Orange Worker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-11-2004 09:04 PM |
Outboard gear | Nick4228 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-24-2002 01:25 AM |
