Old 05-31-2018, 04:43 AM
midnightrambler midnightrambler is offline
Default Re: PT 2018 Copy and paste / duplicate doing something strange.
Originally Posted by PMF Media View Post
Um... no it didn't, everything snapped perfectly to the grid regardless of Samples/ticks as time ref in all versions prior PT 11 (PT 10 and down
I too have a working version of PT10 and can confirm that when I duplicate clips in 10 they park themselves perfectly behind the preceding clip, on the grid every time.
I don't think so. Here is PT10 working exactly as it should regarding ticks and samples, i.e. drifting off the grid in "samples" mode, staying bang on in "ticks" mode. QED.
https://youtu.be/0QjDk9GlAgo
BUT.....
Interestingly though, trying to perform this exact same procedure in PT2018.4 and using "cmd-a" to select all the clips creates a selection that extends beyond the actual MIDI clip boundaries on the track. Not sure what this is all about...?!!
https://youtu.be/4f98zqHXbIk
Old 05-31-2018, 04:10 PM
PMF Media PMF Media is offline
BUT.....
I see... I'm talking AUDIO rather than MIDI, the example in the vid is certainly extreme! I usually(99% of the time) do all my major MIDI work in LPX then move the audio over to PT for editing and mixing. I still contend that up until PT 11, sample rounding never caused me issue - with AUDIO clip/regions.
Old 06-01-2018, 03:15 AM
Yeah I thought you might say that, so I've made another video for you proving that PT10 does exactly the same thing for audio, i.e. drifting off the grid in "samples" mode, staying bang on in "ticks" mode. You're welcome. :)
https://youtu.be/CmCQGoqZ-0I
Old 06-03-2018, 06:12 PM
innesireinar innesireinar is offline
I live with this rounding error since vs 6. But since vs 12 I'm encountering this on midi clips as well. This is very annoying because sometimes when copying midi clips they lose the first note/s. Upgrading from pt 11 to 12 was a disaster
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 06-04-2018, 12:13 AM
Have you not read a word I’ve written?
  #16
Old 06-04-2018, 08:08 AM
What I'm saying is not what yo are talking about. I'm talking about rounding error on midi clips. Never happened before pt12. At least from my experience
  #17
Old 06-20-2018, 10:38 AM
Evermore Evermore is offline
Confirmed! I'm on 2018.4 and I have the same issue. I get random overlaps and lengths when I copy or duplicate Audio/midi clips. This is definitely a bug.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Apogee Symphony IO mkii
  #18
Old 09-20-2018, 05:32 PM
Come on Avid, this issue, especially on midi material, is unacceptable, don't force me to downgrade to yosemite/PT11.
  #19
Old 09-21-2018, 01:13 PM
ibbod0 ibbod0 is offline
I don't think anyone still complaining about this even bothered to read the reason why it happens. if you set the tempo to 127bpm and you copy one bar of audio recorded at 48khz from bar 1 (which is 90709 samples long) into bar 2 (which is 90708 samples long), how do you suppose that it should not overlap onto bar 3?
if you duplicate it with a sample timebase it will duplicate end on end with no overlapping but it will get one sample behind the bar line every few bars (depending on the tempo)
if you duplicate with ticks timebase, it will stay on the grid and the last sample will be chopped off every few bars (again depending on the rounding cause by the tempo)
I'm really interested in how other DAWs handle this. I'm guessing they choose sticking to the grid vs being sample accurate so their users don't think they're stupid.
By the way!
You won't have any issues if you use the following tempos at 48Khz sample rate (BPM):
37.5. 40, 46.875, 50, 60, 75, 93.75, 100, 120, 150, 187.5, 200, 300, 375,
  #20
Old 09-21-2018, 05:42 PM
By the way!
Even by duplicating clips with ticks timebase the clip start sometimes are off grid line. Btw I learned to live with this when handling audio material, but since pt 12 it happens on midi clips as well. And it is hard to live with
Duplicate/Copy Paste Issue Roulette Records Pro Tools 12 8 04-19-2016 01:41 PM
Duplicate/Copy&Paste errors with Samples on Grid Kikonda12 macOS 1 03-07-2013 04:17 AM
Strange problem with audio/midi tracks after copy/duplicate Nullfusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2011 07:17 PM
Smile Strange problem with audio/midi tracks after copy/duplicate Nullfusion Pro Tools 9 1 09-16-2011 04:35 PM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
