Old 11-10-2010, 08:26 AM
3001 Studios 3001 Studios is offline
Default Control Room Level
Is it possible to use the control room level on a Mix Control to control PT9 output within Pro Tools?
Or is the only solution to set up a 2nd interface with Studio Monitor Express?
Jeff
Old 11-10-2010, 11:44 AM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
Default Re: Control Room Level
there is no dedicated Control Room level in Pro Tools; the CR knob has nothing to be linked to within Pro Tools.
Old 11-10-2010, 11:51 AM
noizgirl noizgirl is offline
Will Studio Monitor Express ever be integrated to work with Protools? I had hoped this would be accessible as part of Eucon implementation in PT9.
Old 11-10-2010, 07:31 PM
Here is the response I got from Euphonix today:
Once we get a true full implementation of EuCon into Pro Tools, the control room knob will function properly with Pro Tools. Currently the implementation of SME only allows for Core Audio devices to work with it.
Old 12-20-2010, 07:00 PM
DigitalMetal DigitalMetal is offline
Iv Had it working in PT9 with studio monitor express, you basically have to used Studio monitor Express as the Audio Driver in PT then it works but the SME Audio driver Gives terrible PT performance so its not really very good.
PT10HD5 PCIX in 64Bit Magma Chassis,
2x192io's + 2x96io's & Legacy io's
Pro Control & Fader Pack
UAD2 Quad, Octo & All Plugins
Black Lion Audio Modified MOTU 24io and 2408MK3 x2
TC Powercore PCI MK2 x2 & Firewire
Softube, Sonnox, Eventide, SSL, McDSP, Waves
Old 01-08-2011, 06:54 AM
losket22 losket22 is offline
hi,
After the installation of SME, i can't use it as Audio Driver in PT9.
What did you do to configure it ?
Thanks
C.
Old 02-18-2011, 10:16 AM
syra syra is offline
Also interested in this.
Old 02-18-2011, 01:22 PM
Originally Posted by losket22 View Post
hi,
Thanks
C.
It just was there in the list of available Audio devices in my PT Settings, this was with OSX 10.6
Anyway to get visual feedback for the Monitor/Control Room level on the Artist Contro Focuret Artist Series 0 11-19-2012 11:46 AM
What level should i keep my drums so theres enough room for editing? rockguitarist1255 Pro Tools 10 16 02-18-2012 10:03 AM
Artist MIX with control room level ! claes1965 Artist Series 1 01-28-2012 09:16 AM
Control room level button works only on one ch maxithev ProControl, Control|24, Command|8 3 11-01-2005 04:34 PM
Mono surround monitoring level in a 5.1 room tomcat Tips & Tricks 1 12-09-2001 12:35 AM
