Old 01-10-2005, 06:36 AM
dodo dodo is offline
Default 6.4 to 6.7. A couple questions
I have an AMD 64bit system with SP2 and I'm running great with 6.4 but I want upgrade to 6.7. Just a couple questions:
1. Do you have to uninstall 6.4 or can you just install 6.7 and it will keep all plugins, etc? The manual doesn't say.
2. If I do a reinstall will I have to do the DEP fix with 6.7?
Thanks
Old 01-10-2005, 07:23 AM
spkguitar's Avatar
Default Re: 6.4 to 6.7. A couple questions
When I did my upgrade from 6.4 to 6.7, the installer prompted me to remove 6.4 first, which I did. After install, all the plugins were still there and available.
However, I did do a complete backup of my system before doing the install, even though I ended up not needing it. It is always wise to do a full backup of your system before doing any major upgrade.
I don't have a 64 system so I can't really comment about the DEP fix. The fix is windows based, not PT based, though so i would imagine if you've done it once, you won't need to do it again.
Old 01-10-2005, 09:38 AM
Camilo Toledo Camilo Toledo is offline
If you have SP2 on you machine you can try the DEP fix, if it does some good, keep it, other wise don't. SP1 doesn't give you that option.
I have a K8V-X/64 bit 3200, 1gb ram with SP1, 6.7 and its running great.
Camilo Toledo
Old 01-10-2005, 09:55 AM
Chuck
Yes I have SP2. Do you have it?
Old 01-10-2005, 12:47 PM
With the prices of hard drives so low, I recommend loading a new drive and put your working 6.4 drive on a shelf. If you have any troubles you can slap in the old drive and go right back to work. If you don't want to take the time to reload everything, use Ghost to copy the old drive to the new one, and then make your changes and updates.
Old 01-10-2005, 01:38 PM
Excellent Idea!!!!!
Couple Questions Skeeter Joplin Tips & Tricks 3 03-01-2010 03:05 AM
Couple of help questions Brazen15 Pro Tools M-Powered (Win) 5 10-23-2007 12:54 PM
Couple questions. Don Geppert ICON & C|24 5 10-05-2006 03:11 PM
A couple questions G_Bender Tips & Tricks 5 10-04-2005 08:15 AM
A couple of questions. the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-16-2005 03:17 AM
