Old 05-06-2018, 11:59 AM
julien-k julien-k is offline
Default PT 2018 Copy and paste / duplicate doing something strange.
Running PT 2018.4 / iMac OSX 10.13.4 High Sierra
Noticing when I copy and paste files that are PERFECTLY on the grid they seem to randomly change lengths? Some files end up shorter? Some stay the same.
Same when I use the duplicate function.
It's exactly the same if I'm using Samples or Ticks. No difference?
Anyone else having this issue???
Old 05-07-2018, 02:13 AM
ibbod0 ibbod0 is offline
Default Re: PT 2018 Copy and paste / duplicate doing something strange.
May be sample rounding? how much is the length changing?
My understanding of this is that because of sample rounding, each bar is not actually the same length of samples. for example if you picked a particularly unlucky tempo/sample rate combination resulting in a bar length ending in .5 of a sample, all odd numbered bars may be 1 sample shorter than even numbered bars. if that makes sense? Someone probably explained it better than me elsewhere.
So basically when duplicating, we are forced to choose between SAMPLES = duplicates the audio perfectly end-to-end but getting slightly off the tempo grid every time you duplicate, or TICKS = keeps the audio perfectly on the grid at the expense of chopping off the end or creating gaps between clips.
Old 05-07-2018, 08:07 AM
Ambroise Ambroise is offline
Yes I noticed the same yesterday when working with midi parts.
I tried different methods and overtime the same bug with sorter or longer length appear. That is very annoying because this bug wasn't there on PT 12.4 which I used before
Old 05-24-2018, 10:13 PM
Hakuoki Hakuoki is offline
I have had this problem since 12.7. I will have a perfect (for argument's sake) 2 measure midi block. It is perfectly 2 measures at max zoom. I duplicate or copy and somewhere along the way the dupe's start losing or gaining fractional ends- either they become slightly shorter or slightly longer. It costs me an INSANE amount of time to zoom check and fight with these midi blocks regions. I produce in PT. So this affects every instrument.
Old 05-25-2018, 08:58 AM
The Weed's Avatar
The Weed The Weed is offline
Search for "Sample Rounding" or "Rounding Error".
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-27-2018, 09:51 PM
psycho_monkey psycho_monkey is offline
This is technically "correct" behaviour and every other DAW is fudging it.
If you switch timebase reference to ticks - it'll behave as you wish.
PT has always behaved like this.
Old 05-28-2018, 05:40 PM
PMF Media PMF Media is offline
Um... no it didn't, everything snapped perfectly to the grid regardless of Samples/ticks as time ref in all versions prior PT 11 (PT 10 and down). I used to be able to duplicate a clip/region and have it snap perfectly on the end of itself add infinitum... now, after the 3rd or 4th duplicate this "sample rounding" "feature" rears it's head and will create timing inconsistencies if not corrected manually.
Indeed, VERY annoying!
Old 05-29-2018, 05:59 AM
Nonsense. I can prove it if you like, I still have a copy of PT10 here.
Old 05-30-2018, 04:34 PM
Well, what can I say... I've been using PT since v6.x and had never encountered this until I upgrade to PT11 (64 bit, I make this distinction because PT was apparently re-coded), I too have a working version of PT10 and can confirm that when I duplicate clips in 10 they park themselves perfectly behind the preceding clip, on the grid every time.
Old 05-30-2018, 05:03 PM
leftalive leftalive is offline
The sample rounding bug has definitely been around for a loooooong time. So much so, that I long ago got used to making every region I create a sample or two shorter than an actual full bar (or however many). It's not terribly annoying once you get used to doing it.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Duplicate/Copy Paste Issue Roulette Records Pro Tools 12 8 04-19-2016 01:41 PM
Duplicate/Copy&Paste errors with Samples on Grid Kikonda12 macOS 1 03-07-2013 04:17 AM
Strange problem with audio/midi tracks after copy/duplicate Nullfusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2011 07:17 PM
Smile Strange problem with audio/midi tracks after copy/duplicate Nullfusion Pro Tools 9 1 09-16-2011 04:35 PM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
