Old 10-07-2011, 10:10 AM
YYR123's Avatar
YYR123 YYR123 is offline
Exclamation Recent O/S Install - Xpand2 Install issue
So i just made the jump up to WIN7X64.
Finally have got all plugin's and autho's hashed out(took longer than i expected). We look good BUT i opened a session last night that I was working on b/f the upgade and it wouldn't open Xpand2. I copied several of the plugins straight from the plugin's folder over to the new install b/c I had several patches on songs that i couldn't lose.
So I installed the full installer for 8.0.4 that DTS sent me on the email.
I am confused why didn't it install xpand2? Can I rerun that to make it install just xpand2?
Is there anything I can check on my system that will let me see what's wrong? This was the original error that it gave me while loading the session.
"Insert A ("Xpand2") has been made Inactive because the plug-in is not present in the plug-ins folder.
Thanks guys.
Daniel
Last edited by YYR123; 10-07-2011 at 10:11 AM. Reason: Optimized title for actual problem.
Old 10-10-2011, 11:38 AM
YYR123's Avatar
Default Re: Recent O/S Install - Xpand2 Install issue
Bump on this guys....Anybody know how to just install xpand2 ??
Daniel
Old 11-02-2011, 08:54 PM
stratpicker stratpicker is offline
Having similar problem after installing PT10. I can find the .big file and when I instantiate Xpand2 I can see all of the factory presets. However when I select one it won't load into the four paths. I've looked to try and find the "map to" executable and I can't even find it now. Need to know what's the fix.....Is it possible to just reinstall Xpand2, and if so how....thanks.
Old 11-03-2011, 10:33 AM
YYR123's Avatar
Stratpicker -
I actually should have posted the fix....I reinstalled PT (for me it was 804) and then did the update 805.
This reinstalled xpand2 - I believe what I had was a plugin file in the folder and that told the installer somehow that it didn't need to install it all over again. I had quite the mess on my hands after I upgraded to WIN7.
I just deleted the plugin files related to xpand in the folder heirchy (sorry for the misspell) and reinstalled PT and I have it now and all works as advertised.
Daniel
Can't install Xpand2, Boom or any of the included instruments! DVDM Pro Tools 10 2 09-03-2013 10:35 PM
XPAND2, MiniGrand and other plugins not active on recent PT 11 install insightsono macOS 2 06-30-2013 09:43 AM
Xpand2 problem after PT10 install jrichview Windows 2 03-10-2012 05:44 PM
No XPAND2! or Boom on new install ztaylor9632 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-19-2010 08:46 PM
8.0.4 and 8.0.3 Install Issue gryphondale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-09-2010 06:59 PM
