Old 12-11-2003, 09:10 AM
tim carter tim carter is offline
Default headphone monitoring problems..
I am having a problem with headphone monitoring while a track is in record mode... It sounds very brittle with a slight delay, I have messsed with the Low Latency and I've set the buffer size to 128 with no effect.. any idea's? Thanks...
Mac G5, 10.5.8, 2 GB, Rosetta 800 w/X-HD Card, Control24, HD2, PT's 8
http://carterbrothersband.com/studio.cfm
Old 12-11-2003, 12:38 PM
RinnyTin RinnyTin is offline
Default Re: headphone monitoring problems..
More information please. Tell us your entire setup.
Old 12-11-2003, 01:58 PM
I have a 002R, Mac G4 1.25 dual.. I'm running into a Tascam DM24 (not yet HUI'd in, just monitoring through it). I just ran my buffer to 64bits and it does sound better. Is this normal.. anything above that sounds like your inside a trash can. thanks
Old 12-11-2003, 02:24 PM
I assume you mean 64 samples, yes that should be all but inaudible. Are you going lightpipe out to the Tascam or analog? If you're going analog, that would explain it, the coversions create latency. If you're going digi, I'm not sure what it is you're hearing. Maybe someone else has that board?
Old 12-11-2003, 02:49 PM
I'm going SPDIF into the Tascam...
Old 12-11-2003, 03:52 PM
Bender Bender is offline
Do you mean you selected Low Latency Monitoring under the operations menu?
003 Headphone Monitoring meanie2188 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-11-2010 12:03 PM
Having Headphone Monitoring Problems Cannibal80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2005 02:40 PM
Headphone monitoring MikeSoloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-18-2003 11:11 AM
Headphone Monitoring Christoph1123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-13-2001 09:06 AM
Headphone Monitoring Greg Malcangi ProControl, Control|24, Command|8 0 12-09-1999 11:54 AM
