Old 05-04-2019, 02:27 PM
musicman691 musicman691 is online now
Default Blue Cat Late Replies external ducking
I've been using Late Replies inside Axiom and would like to be able to use the ducker fed by an external bus send. However I can't find any way to do that and there's nothing in the manual on how to do that. The ducking function & controls are described and there's a block diagram but nothing on how to feed in an external ducking control. Got a support request in to Blue Cat but am hoping someone here might know the answer. Google turns up nothing on how to use the external ducking feature.
Jack
QAPLA!
Old 05-04-2019, 03:00 PM
amagras amagras is online now
Default Re: Blue Cat Late Replies external ducking
I think Axiom doesn't have sidechain input so the only way to trigger Ducker is by using the direct signal of the track Axiom is inserted. You have to insert Late Replies as a separate plugin to have this option and still I wouldn't know how to route that signal to the Ducker. If you tag Blue Cat hopefully they prove me wrong.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-04-2019, 05:21 PM
You're right in that Axiom doesn't have an apparent sidechain input that I can find (nor have you it seems). And that's sad if it's missing as that would be a good thing to have when using LR inside Axiom.
I've looked at the LR manual and they make no mention of how to use the eternal sidechain. I know they have MIDI control for a lot of stuff but even that doesn't cover the external sidechain business. There is a thing where one can control the sidechain enable via MIDI but nothing about using an audio input.
I have a support email into Blue Cat with this and have also asked over on Gearslutz in what's about a 2 year old thread.
Supposedly the Late Replies that's in Axiom is the same as the standalone LR (one that can be used as a plugin on it's own).
Something that just hit me - I wonder if this is only usable for vst and au format users?
Jack
QAPLA!
Old 05-04-2019, 05:45 PM
I think they didn't intend the LR version inside Axiom to be a substitute Late Replies, only a cool delay you can use on your guitars.
amagrasmusic.com
Old 05-05-2019, 02:08 PM
To have Late Replies as a separate plugin you have to have a separate license asset for that. Right now that's doable for $39 US and a separate license asset for Destructor is $29 IIRC.
Agreed on that. I'm surprised they don't have something in the manual for Axiom about this.
Something I found in today's testing when I inserted a separate compressor plugin that normally has an external sidechain available that disappears when used in Axiom. Using the sidechain in standalone Late Replies (was Axiom) (I downloaded the demo to a separate partition) is the same as a sidechain in any other plugin that has one. Send from a PT track to the key input on the plugin. Adjust controls to taste.
Jack
QAPLA!
Last edited by musicman691; 05-06-2019 at 03:33 AM. Reason: changed Axiom to Late Replies - text in red
Old 05-05-2019, 02:10 PM
You mean Late Replies standalone?
amagrasmusic.com
Old 05-05-2019, 02:49 PM
For external sidechain use? Yes. And yes it requires a separate license & download if you have Axiom. There is a package called energy pack and IIRC that has Axiom as well as embedded and standalone versions of Late Replies and Destructor.
Jack
QAPLA!
Old 05-05-2019, 02:58 PM
Sorry Jack, I'm still confused, you did install Axiom in another partition or Late Replies?
amagrasmusic.com
Old 05-06-2019, 03:38 AM
My apologies for that screw-up. The standalone I downloaded in another partition was Late Replies. I corrected my post above. Too much tequila and rum
Got a reply back from Blue Cat support and there is no external sidechain input in Axiom. Made a suggestion to them that maybe they can put a note to that effect in the Axiom manual with respect to LR.
Jack
QAPLA!
Old 05-06-2019, 01:42 PM
Those two do crazy things when they get together
Good suggestion, just a mention should do it.
amagrasmusic.com
HTML code is On
Blue Cat's Late Replies 1.3 Creative Delay Released / On Sale bluecataudio AAX Plug-ins 0 11-12-2018 03:56 AM
Blue Cat's Late Replies 1.1 Creative Delay Workstation & Host Released! bluecataudio AAX Plug-ins 3 06-05-2018 02:32 AM
Blue Cat's Late Replies - New Creative Delay / Multi FX & Plug-Ins Host Released bluecataudio AAX Plug-ins 2 08-25-2017 12:23 PM
Blue Screen recording MIDI on External Clock bakerja Pro Tools M-Powered (Win) 2 11-26-2009 03:43 AM
