Old 04-22-2019, 06:47 PM
rebelcowboy rebelcowboy is offline
Default Cant load avid bundle
H Folks,
Pro tools 12.4 has been working perfectly for me but with no way to add the avid bundle and get it to load.
The message i get is - "the following plugins failed to load because they are not valid 64 bit aax plug-ins"
I have updated my application manager and also my ilok.
Is there one preference i need to click to make the entire avid bundle 64 bit?
I uninstalled and re installed everything with same result. I then wiped my computer completely clean of Protools and redownloaded 12.4, first effects, first instruments and the avid bundle and still got the same error.
My computer is a mac mini i7, 16gigs ram, osx 10.8.5 mountain lion
I hope someone can send me in the right direction on this one.
Thanks!
Old 04-22-2019, 07:19 PM
Top Jimmy's Avatar
Default Re: Cant load avid bundle
To what “Avid bundle” are you referring?
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 04-22-2019, 07:29 PM
Avid Complete Plugin Bundle
Old 04-22-2019, 07:40 PM
Top Jimmy's Avatar
I would hazard a guess that you need to regress the plugins to whatever previous versions that were known to be compatible with Pro Tools 12.4. Obviously this makes the bundle installer useless for you.
James Cadwallader
Old 04-22-2019, 08:01 PM
Thanks Jimmy,
Any idea on how to do that?
Old 04-22-2019, 08:10 PM
Top Jimmy's Avatar
Visit the webpage for each plugin and download whatever version was current when 12.4 was released. Yes, this is going to be labor intensive. You can verify if this will work by installing one and testing it with Pro Tools.
James Cadwallader
Old 04-22-2019, 08:13 PM
Ok sounds good, Im going to give one a shot right now.
Thanks again for your help
Old 04-22-2019, 09:04 PM
Perfect fix. Thanks so much!!
HTML code is On
Avid Complete Plugin Bundle / Fail to load Zergei AAX Plug-ins 1 03-16-2018 11:54 PM
Avid Pro Tools Demo won't load. SteveGarman Pro Tools 11 1 06-15-2014 07:34 PM
new factory bundle load mattgoss Tips & Tricks 1 03-19-2007 08:59 PM
Cannot load IK Multimedia Bundle ImMana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-05-2004 12:07 PM
Sampletank (IK bundle) hangs while trying to load catcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2004 11:08 AM
