  #151
Old 08-03-2012, 06:39 PM
ryu5969 ryu5969 is offline
Default Re: basis of class action lawsuit?
Originally Posted by nethawk7 View Post
new driver had no effect on this
that's weird. i had a session last night for the first time after the driver update, and the headphone issue seems to be gone for me.
i have a different problem now though. when i tried to use the Mbox 3 Pro in low latency monitoring mode, the hardware input doesn't get to the Master buss in the Mbox Pro software. the Hardware Inputs meters move and the software returns get to the Master buss i can monitor that, but not the hardware inputs.
  #152
Old 08-06-2012, 02:49 PM
after trying different things i found out this problem goes away as soon as i record a little bit of audio.
  #153
Old 01-21-2013, 05:37 AM
LukeCincotta LukeCincotta is offline
Default Re: Occasional headphone out problems with Mbox 3 Pro
the latest driver is out on avid's site: http://avid.force.com/pkb/articles/e...nload/en375655
After getting my first pro replaced for these problems a few months ago, I thought my new unit was all good. 3-4 months later and I'm getting bursts of white noise through both monitors and headphone outs. Upon applying the driver update, my mbox is no longer visible at all in my output devices. At all. Completely gone.
I just do not understand how this can still be an unresolved issue? Seriously?!
  #154
Old 01-31-2013, 12:18 PM
docscholl docscholl is offline
I wish I'd read this thread before I purchased my Mbox 3.
I've got a similar headphone problem: one input works, the other does not.
That, and the fact that I keep getting a "controller personality" error message when using the Mbox with my Pro Tools LE version 8.5 (but not with version 8.3).
Is this my wake-up call to abandon more than a decade of loyalty to Avid?
003+ Factory & Mbox 3
Apple powered by OS X 10.5.8:
iMac 2GHz Intel Core 2 Duo/4GB SDRAM (8.0.5LE)
PreSonus DigiMAX FS
  #155
Old 05-11-2013, 02:37 PM
suburbano suburbano is offline
>> FIX <<
open the box and there is a data cable with a black metal square of about 2 inches on it that easily detaches, attach it properly and everything should work fine
  #156
Old 06-28-2013, 10:14 AM
CHRIS AIKEN CHRIS AIKEN is offline
Originally Posted by DigiTechSupt View Post
We're still working on this and, for various reasons, I can't give anything more than that info.
I've got the same problems happening with the most current versions of protools and drivers.
Was this fixed? I skimmed through the thread and this seems like the above quote is the last post from Digi. Why is that? When you say you're working on a fix for a pretty major problem, I think it's pretty uncool not to come back with an update!
What's the status of this bug?
Chris
  #157
Old 07-02-2013, 08:54 PM
Anyone from Avid care to update this?
Hackintosh 3.5 GHz Intel Core i7 - 10.13.6 -16 gigs Ram - Lynx Aurora 16 Thunderbolt - Protools 2018.7 HD
  #158
Old 11-28-2013, 08:08 PM
Allbaldo Allbaldo is offline
Mine has all the above problems too. Headphone outputs working 50% of the time, and when I turn the unit on and off, it only occasionally fixes it. My 002 was rock solid in comparison. Bumming me out.
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-12-2012 11:34 PM
002 console headphone problems mote45 Tips & Tricks 2 01-03-2006 10:15 AM
Having Headphone Monitoring Problems Cannibal80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2005 02:40 PM
mbox - occasional playback distortion bjkiwi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-05-2005 12:19 AM
headphone monitoring problems.. tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-11-2003 03:52 PM
