PT keeps crashing..im at my wits end..PLEASE HELP!
this has been a reoccurring problem since a few days before PT 8 came out...i have done EVERYTHING.
i have uninstalled and reinstalled pro tools 8 4 times..i have trashed the prefs & databases over and over again. I tried the plugin thing i took EVERY plugin out of the plugin folder and added them one by one which took FOREVER(even the plugins that came with PT8)..i took out all the plugins i have added and just ran PT witht he stock ones and it did fine..no crashes at all and i kept adding and CONTINUED to NOT get crashes untill i got to breverb then it crashed..i said to myself "i found the problem" i deleted breverb and it STIL crashes after that. I've posted at DUC, protoolsuser.net EVERYwhere.. i dont know why pro tools has started crashing like this..it has been working fine for MONTHS when i first got 7.4 no issue at all...i will say this again that it did NOT crash at all when i took all of the plugins out and it STILL didnt crash when i was adding them untill i got to breverb..so i thought it was fine then it came back. At one point i thought it was my external drive(WHICH IS FIREWIRE400 & 7200RPM) SO i went out and bought another external seage 1.5tb external drive(WHICH IS FIREWIRE400 & 7200RPM)..still crashing so its not a drive.. im at my witts end guys..has this app ever had you so stressed out? and you have serious projects on the line?...please help me When it crashes its only when opening,saving & closing session PT 8 quits unexpectedly...i even made a new account on vista and see if that worked STILL nothing helps: im using an MBOX 2 here is the crash im getting: http://i121.photobucket.com/albums/o...6/pt8error.jpg my LAST option only seems to be a reformat(which i really dont have time for you even want to do) but if that fails then im FRESH out of option i've tried everything in the book guys..im truly at the verge of being defeated here, i have no idea what to do anymore. system specs: > Mainboard : Gateway RS780 > Chipset : Advanced Micro Devices (AMD) > Processor : AMD Phenom 8400 @ 2100 MHz > Physical Memory : 6144 MB > Video Card : ATI Technologies Inc ATI Radeon HD 3200 Graphics > Hard Disk : WDC (500 GB) > Hard Disk : WD (500 GB) > DVD-Rom Drive : HL-DT-ST DVDRAM GH15F ATA Device > DVD-Rom Drive : MFOPQDY UFGHIZCDU SCSI CdRom Device > Monitor Type : Hewlett Packard HP f1905 - 19 inches > Network Card : Marvell Semiconductor (Was: Galileo Technology Ltd) Yukon 88E8071 PCI-E Gigabit Ethernet Controller > Operating System : Windows Vista (TM) Ultimate Professional 6.00.6001 Service Pack 1 > DirectX : Version 10.00 > Windows Performance Index : 4.0 please help. |
Re: PT keeps crashing..im at my wits end..PLEASE HELP!
your os, vista is 32 bit?? i might also try pulling some ram out. you have about 6 gb installed, pull it down to at least 4.
is this machine online?? if so virus scan, spyware, malware, cookies deleted, all that good stuff needs done. any other new software installs or updates right before it started??? do you keep images via acronis or norton ghost of your machine?? if not you should. have you tried restoring to a date where it was working correctly?? have you monitored your ram usage when system is in use, via task manager?? might need to do the 3gb switch. everyone is gonna start asking for a sandra report. details on the help us help you sticky at the top of the page.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
yea i thought about restoring my system to a previous date im going to try that next..no i have not gotten norton ghost..i will get it.
umm as far as update i think i got a few minor windows update i have not monitored my ram usage..i will try that as well.. here is my sandra report: SiSoftware Sandra System Host Name : NIKKOSSTUDIO-PC User : Nikkos Studio Workgroup : WORKGROUP Processor Model : AMD Phenom(tm) 8400 Triple-Core Processor Speed : 2.10GHz Cores per Processor : 3 Unit(s) Threads per Core : 1 Unit(s) Type : Tri-Core Internal Data Cache : 3x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 3x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 2MB, ECC, Synchronous, Write-Back, 32-way, 64 byte line size, 3 threads sharing System System : Gateway DX4200-UB101A Mainboard : Gateway RS780 Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : American Megatrends Inc. 7B3P081G Total Memory : 3.25GB DIMM DDR2 Chipset Model : Acer RS780 Host Bridge Front Side Bus Speed : 1x 200MHz (200MHz) Chipset Model : AMD (Family 10h) Athlon64/Opteron/Sempron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1.8GHz (3.60GHz) Total Memory : 6GB DIMM DDR2 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Samsung M3 78T5663QZ3-CF7 2GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-6-6-18 3-24-6-3) Memory Module : Samsung M3 78T5663QZ3-CF7 2GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-6-6-18 3-24-6-3) Memory Module : Samsung M3 78T2863QZS-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-6-6-18 3-24-6-3) Memory Module : Samsung M3 78T2863QZS-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-6-6-18 3-24-6-3) Video System Adapter : ATI Radeon HD 3200 Graphics (256MB, PCI, SM4.0) Storage Devices WDC WD5000AAKS-22A7B0 500GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) Seagate FreeAgent XTreme 2TB (FireWire/1394, NCQ) : 1TB (F:) WD My Book 500GB (USB) : 466GB (I:) IOI CF/MicroDrive (USB) : N/A (J:) IOI SM/xD-Picture (USB) : N/A (K:) IOI SD/MMC (USB) : N/A (L:) IOI MS/MsPro (USB) : N/A (M:) HL-DT-ST DVDRAM GH15F (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (D:) MFOPQDY UFGHIZCDU (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (E:) Logical Storage Devices PQSERVICE : 10GB (NTFS) OS (C:) : 456GB (NTFS) @ WDC WD5000AAKS-22A7B0 500GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Pro Tools LE (D:) : 8GB (CDFS) @ HL-DT-ST DVDRAM GH15F (SATA150, DVD+-RW, CD-RW, 2MB Cache) CD-ROM/DVD (E:) : N/A @ MFOPQDY UFGHIZCDU (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) FreeAgent Drive (F:) : 1TB (NTFS) @ Seagate FreeAgent XTreme 2TB (FireWire/1394, NCQ) Removable Drive (J:) : N/A @ IOI CF/MicroDrive (USB) Removable Drive (K:) : N/A @ IOI SM/xD-Picture (USB) Removable Drive (L:) : N/A @ IOI SD/MMC (USB) Removable Drive (M:) : N/A @ IOI MS/MsPro (USB) My Book (I:) : 466GB (NTFS) @ WD My Book 500GB (USB) Peripherals LPC Hub Controller 1 : Acer IXP SB600 SMBUS Controller LPC Hub Controller 2 : Acer SB700 LPC host controller Audio Device : Acer IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Audio Device : AMD (ATI) RS780 Azalia controller Audio Codec : AMD (ATI) 791Ah Serial Port(s) : 3 Parallel Port(s) : 1 Disk Controller : Acer SB700 SATA Controller [IDE mode] Disk Controller : Acer SB700 IDE USB Controller 1 : Acer SB700 USB OHCI0 Controller USB Controller 2 : Acer SB700 USB OHCI1 Controller USB Controller 3 : Acer SB700 USB EHCI Controller USB Controller 4 : Acer SB700 USB OHCI0 Controller USB Controller 5 : Acer SB700 USB OHCI1 Controller USB Controller 6 : Acer SB700 USB EHCI Controller USB Controller 7 : Acer SB700 USB OHCI2 Controller FireWire/1394 Controller 1 : JMicron Technology IEEE 1394 Host Controller FireWire/1394 Controller 2 : Creative Labs Audigy 2 Firewire Controller System SMBus Controller 1 : AMD IXP SMBus System SMBus Controller 2 : AMD AFS SMBus Printers and Faxes Printer : Send To Microsoft OneNote Driver (300x300, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Scanners and Cameras Digital Camera : CF/MicroDrive (USB) Digital Camera : MS/MsPro (USB) Digital Camera : SD/MMC (USB) Digital Camera : SM/xD-Picture (USB) Network Services Network Adapter : Marvell Yukon 88E8071 PCI-E Gigabit Ethernet Controller Wireless Adapter 1 : Compact Wireless-G USB Adapter (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows Vista Ultimate 6.00.6001 (Service Pack 1) Platform Compliance : x86 Windows Experience Index Current System : 4.0 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Get rid of the Creative Labs cra... stuff... what happens?
Rail
well i use my creative labs stuff for playback outside of pro tools
Rail
ok,ill try that
i did a reformat..everything should be ok
did u manage to get it all sorted? only im interested in purchasing the seagate xtreme 1tb n wanted to know if it wil function with pro tools ..
i ended up getting everything sorted out i did a reformat and the problem went way. The seagate drive is pretty good i'd definitely recommend you get it.
P.S. i just recently started having problems again when PT CRASHING out of no where i may try to see if the digibase is corrupt if that does not fix it i dont know what im going to do...i have reformatted my computer 4 times just to fix PT issues...ridiculous |
At my wits end!!! Digi 003 AHHHHH! | melloj | FireWire & USB Audio Interfaces (Win) | 1 | 03-08-2014 06:19 AM |
PT 8.0.4 has been crashing | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-04-2010 04:38 AM |
At wits end with 003+ hardware probs!!! | dave_le_dave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-13-2009 06:43 PM |
Just about at my wits end..... | RickyRae | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-29-2008 06:40 PM |
At my wits end!! Bounce problem with LE 5.1.1 | zulu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-28-2004 06:02 AM |
