Old 08-02-2013, 07:05 PM
FrankCan FrankCan is offline
Default Pro Tools 8.0.4 with Aria Player Plugins Finale 2012
It seems I can't adjust the volume fader in either the Aria Player or in Pro Tools. The Aria Player volume snaps back to the quietest level and the P.T. moves up, but doesn't seem to get much louder. I called Garritan. They said it's probably in the host software,which is P.T. I tried to adjust the Automation, but it only works to adjust the P.T. fader. It's still quiet. I also adjusted the velocities of each note. Any help would be appreciated. I've got two drum tracks. One of them is adjustable and the other isn't.
Imac Core Duo
Pro Tools 8.0.4
Thanks!
Old 08-04-2013, 09:18 AM
Default Re: Pro Tools 8.0.4 with Aria Player Plugins Finale 2012
Hi Everyone,
Problem solved! Apparently my Midi keyboard volume was down low. I didn't think to check it earlier. It's a mystery to me why that would happen as the track was already recorded and saved. Maybe it's an automation setting or something dealing with the midi controller settings? This is beyond my expertise. If anyone might be able to give me an explanation it would be good to know.
Thanks.
Old 08-06-2013, 05:44 PM
Hi Everyone,
Apparently it is doing the same thing it did before? Although I can actually hear the drum track this time it's not jumping out at me. Any suggestions would be appreciated. See above for explanation.
Thanks,
Frank
mac mini 2012 can run pro tools ? smcchris macOS 6 11-10-2012 05:52 AM
Garritan Aria Player Question Julia B Virtual Instruments 0 01-12-2011 02:25 PM
Media Player, CD Player in pro tools ACDCfreak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-20-2007 10:17 AM
Pro Tools and Finale ASPSA General Discussion 3 06-25-2007 01:21 PM
Finale and Pro Tools dronicle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-27-2006 08:31 PM
