I fried my 001! (tech question)
Hi. I I think I fried my input #3 with a very high level of signal. What is there to be changed? The TL074? Or the ADC? There is little level coming thru..
Re: I fried my 001! (tech question)
Mundoz,
I have a problem with very low level on analog ins 3 and 4 on my 001. I haven't taken the time to troubleshoot it, since I was using the ADAT inputs with a Tango 24 converter, but I am concerned. I was thinking that it might have just been a misconfiguration, (I was in a hurry and am just a beginner to boot.) I too, would like to know if there are any known issues or hardware problems with the 001, and if there are any fixes. (I'm out of warranty, so its a little late to send it back to Digi.) Thanks for any help if anyone has ideas. |
There is a sort of known issue with the 001 and bad solder connections to the PCB on the connectors, whcih over time can cause low level. try wiggling the connector in the unit while sending signal through it. If it cuts in/out, gets louder/quieter, you need to open the unit and resolder the connections from the connector onto the printed circuit board(PCB).
Also, inputs 3-8 have a software sensitivity adjustment in the setup menu. Make sure they are set to the proper sensitivity for the level you are inputting to them. |
Don´t fry your 001. Imagine the look of the beautiful faceplate after that action...
Just open the box resolder the connections and you´re ready to go. Greets Markus
www.marcousticaudio.de |
Resolder ALL the PC board to connector points, not just the ones that are problematic.
G4 DP 867 / OS X 10.2.8 1GB RAM DIGI001 PT LE 6.0.1 "The artist is nothing without the gift, but the gift is nothing without work." - Emile Zola |
It's a sudden thing, as the poor quality solder point begins to fail. sometimes you begin to get low levels, or intermittant levels, or no level at all.
Cheap labor, cheap wave soldering machines. |
Digi Tech... question | AdamF | Pro Tools M-Powered (Mac) | 2 | 05-18-2005 11:25 AM |
tech question | Zoolander | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-16-2002 03:30 PM |
HD Tech Question | the dude | Pro Tools TDM Systems (Mac) | 1 | 01-28-2002 07:06 PM |
Mac tech question | rschweng | Digidesign Hardware & Software | 5 | 05-06-2001 10:58 AM |
QUESTION FOR TECH SUPPORT | DEST | Pro Tools TDM Systems (Mac) | 1 | 11-16-1999 05:10 PM |
