PT12.4 Track Freeze Random Naming?
Hey all,
A very minor query, but for me on 12.4 all is working very nicely thus far, however when I freeze a track, the file in the edit window is consistently being named after a different track in the session. I was also getting a similar problem in 12.3.1 when I commit a track: the newly created track would be named after a different track in the session.... Actually this is more annoying than the freeze behaviour I'm seeing, as both the file and the track title are incorrect. Any thoughts as to what I may be doing wrong here? I'm not seeing loads of others raising this as an issue, so I'm assuming it's just me..! Thanks
Mac Pro 2019 3.5GHz 8 Core 48GB RAM OS 13.6.3 Protools Studio 2023.12 Antelope Orion 32, Vienna Ensemble Pro 5, UAD Quad PCIe |
Re: PT12.4 Track Freeze Random Naming?
They are going to need more information on your system before giving some help, there's a thread named "help us help you" that explains best than I do.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Thanks.
System info is in my signature, but I'm aware that the signature isn't always shown (especially if you're on mobile..) It's: Mac Westmere 6 core 3.3Ghz, 24GB RAM, OS 10.10.5, Protools 12.4, Apogee Quartet AJA I/O Express
Ok, so I'm wondering if this might be a product of hosting my VI's in VEPro (which I've previously done 100% of the time)
Today I'm working on a much smaller setup than my usual template, so I decided to try hosting everything natively in PT and using Freeze, instead of having everything (by which I mean an 18GB template) loaded in VEPro. Track naming seems to be behaving exactly as you'd expect. Any other VEPro users seeing track name weirdness?
I use VEP, but haven't seen any issues with naming. PT gives me the correct name + the suffix cm. Not tried 12.4 yet.
I've not used the commit a great deal, but I was consistently getting the same issue (in PT12.3.1) where any committed track was being named 'Violins 2', which although not a deal breaker, it's certainly a pain (especially if you try and commit more than one track at a time!) As I say, I'm on a smaller session today (in PT12.4) with everything hosted internally in PT and it's all behaving as expected. If I get some free time I'll have another look at the previous sessions which were causing issues and see if I can pin it down.
Out of curiousity; do you have track and edit selection linked? I usually have that feature on.
I have looked to see if I've had a different track highlighted than the one I was trying to commit, but I don't think it's the culprit... As I say, I was getting every track renamed as 'Violins 2' irrespective of what was selected or highlighted. The Violins 2 track wasn't even the first track in the session...!
REQ to PT12 Track Freeze Beta Team: | seanbil | Pro Tools 12 | 0 | 12-10-2015 02:00 PM |
PT12 - "freeze track" feature | Dave Lang | Pro Tools 12 | 52 | 01-29-2015 08:05 AM |
Random hard freeze | doug kaufman | Windows | 1 | 10-19-2014 07:57 PM |
Random Naming for Audiosuite Renders | Polaris | Post - Surround - Video | 10 | 10-23-2004 09:52 AM |
Random PC Freeze | cron0012 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-03-2001 07:56 PM |
