Any programs to adjust sounds you make?
Like in sampletank, you can add effects to the preloaded samples they have in there like, AM Modulation, FM modulation etc. Wondering if there were any programs like that out there specifally made to load in your samples and add effects to them? Is there anyway to load your own samples into sampletank? Thanks for the help.
[TheLP] |
Re: Any programs to adjust sounds you make?
Check out Antares Filter. You assign it as an insert and you can do some very interesting or wierd things with your audio. www.antarestech.com
Sampletank is actually a ROMpler and not a Sampler. I believe you can import samples and mappings in other formats.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Whats the difference between a ROMpler and a sampler? And a I demoed the antare filter, its really nice.
[TheLP] |
Yeah, I would tend toward something like Kontakt, GigaStudio (ver 3, once availanle, will be cool for the Rewire aspect, plus Gigapulse), or grabbing an app like CoolEdit, SoundForge, or Wavelab for that type of thing.
On the other side of things, you already have a very powerful tool at your fingertips: Pro Tools! Could always load samples in via Import Audio, and then AS 'em to your heart's cntent. What you can do is limited only by imagination, and plugins available. To that end, FXpansion VST-RTAS wrapper lays an impressive set of tools, even just via the freebie VST's out there. While a good sampler app (like Kontakt) can be a time saver in some ways, an app that can do batch runs will be a boon when ding sample creation, simply due to the repetitive nature of it. However, sometimes doing batch processing on a set of samples can be a no-no, as each sample may need specific attention, re: adjusting length, editing, etc , and THEN applying FX for sound sculpting.
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
I want to learn to make a tutorial what programs do I need | phatbeatstudio | Pro Tools HDX & HD Native Systems (Mac) | 3 | 10-17-2012 04:24 AM |
Fine adjust fader in edit window caput! command+adjust | crizdee | Pro Tools TDM Systems (Mac) | 2 | 12-09-2008 03:55 PM |
HELP - Need to make a metronome that sounds 'nice' | Nicholas Turner | Digidesign Hardware & Software | 10 | 04-05-2004 05:48 PM |
how to make a template that will make LE 5.3 stay put over two monitors?? | lavoll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-10-2003 03:43 AM |
decent keyboard to make drum sounds etc | matthewinphilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-30-2000 10:12 PM |
