#121
Re: Delay Compensation Bug
Certainly the conversation didn't end with those words as no official would ever end a discussion regarding software bugs saying that your concern is not a priority. They'd soften the blow with something. But with what, I couldn't guess. Please tell us what other information they provided - how they explained that such a serious issue was "not a priority."
#122
Still, ProTools has had issues with Delay Compensation every since its earliest days. I can't remember a time when it worked as advertised with much consistency. We're too often restarting in order to get DC to work again. Years and years and years have passed and they're not repairing this "feature." |
#123
Iīve already tried that and it didn't help unfortunately. Best regards, Markus
Windows 10 Intel core i7 4790k, 16Gb ram MacBook Pro Retina 13" late 2013 OSX 10.12 Intel Core i5 2,4 GHz 8GB Pro Tools 2018.4 Eleven Rack + Expansion pack RME Fireface UCX |
#124
Is this only an issue with Strike -- I just tried duplicating the issue with Superior Drummer and I couldn't get it to fail. Playback is tight. I'm using PT 11.1.2 with OSX 10.9.2.
I don't have Strike installed and can't try that but I did give Omnisphere a go and it plays properly as well. |
#125
The problem for me is with EZdrummer and NI different Abbey Roads Drummer. I donīt have Superior so I canīt confirm on that. But it probably is problems with other VI as well. How did you set it up to test it? Did you for example put 3 maximizer on one of the tracks that you are sending one of Superior channel to? Regards, Markus
Windows 10 Intel core i7 4790k, 16Gb ram MacBook Pro Retina 13" late 2013 OSX 10.12 Intel Core i5 2,4 GHz 8GB Pro Tools 2018.4 Eleven Rack + Expansion pack RME Fireface UCX Last edited by surstromming; 03-30-2014 at 12:35 AM. Reason: Typo |
#126
OK so I did get it to fail eventually, after adding more plugins. And once it failed I had to restart ProTools to get it to work again. Merely closing the session and reopening didn't cut it. BUT... it does now work, even with the amount of plugins which caused it to fail in the first place.
I'll keep playing around and try to find some useful consistencies. |
#127
Could you maybe post a screenshot of your mixer, how you have it set up when testing this? Because even restarting PT wonīt get this to play in sync for me. And I don't think it has for other users either. The only workaround that I know of is in the link below, and that has been confirmed by Avid to another user who was in contact with Avid in post #26 on that page. Read about the workaround here: http://duc.avid.com/showthread.php?t=348977&page=3 Best regards, Markus
#128
For years I've suspected that DC gets buggy when it's toggled during playback. It can happen when playback is stopped, too, but it seems more likely to occur if PT is being asked to compensate, or ignore compensation, while things are running. So I never toggle during playback, as is done in that video where there's an obvious timing problem.
Is that related to the reason why I'm not getting timing errors? Maybe. Doubtful, but at this point who knows? I'll dive back in at some point and post a screenshot then. |
#129
What video are you referring to when delay compensation is toggled during playback? I donīt see the user in the first post in this thread toggling delay compensation? I have never toggled that either. So I donīt think that is the reason at all. I have tried many times to open the exact same session in PT10 and then everything is ok. But opening the same session again in PT11, itīs not. And Avid is obviously aware that ADC donīt work in a multi-out VI setup in PT11. The question is if they are ignoring it, which at this point seems to be the case. But I really hope itīs not and that they are working on a fix. Regards, Markus
#130
major PT11 delay compensation weirdness. | frozenintime | macOS | 18 | 02-18-2015 05:38 AM |
LE delay compensation plug ins | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-14-2007 11:57 AM |
Plug-in Delay Compensation | Nard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 10-03-2006 05:18 PM |
Plug-In Delay Compensation | guitar131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-31-2005 03:31 PM |
Plug In Delay Compensation | tj_davies | Pro Tools TDM Systems (Mac) | 7 | 09-29-2004 11:51 AM |
