  #5491
Old 12-08-2013, 10:02 AM
cruisemates cruisemates is offline
Default Re: i7 Builds - Specs and Results
Another question:
Samsung 840 Pro 120 SSD
Is this big enough for an OS drive including all the extra software (Melodyne, Addictive drums, Eleven Rack, SampleTank, Reaktor, etc...?
If not how big do you need - and is this really better and faster than a "spinner?"
- but the second mouse gets the cheese
  #5492
Old 12-08-2013, 10:14 AM
Default i7 Builds - Specs and Results
Originally Posted by cruisemates View Post
Another question:
Not in my book, even with samples on a different drive. (And not that an Eleven Rack takes any disk space, that is just a small driver.)
There is a small performance kick in the 840 drives at 256 GB and above, just due to NAND flash chip fan out/parallelism inside the drives. I would just always start at least there in size, and for a boot/system drive that is read mostly the lower-prices (and larger capacity up to 1TB) Samsung 840 Evo drives are great.
And yes, all definitely better than a spinner, especially for a boot drive.
  #5493
Old 12-08-2013, 10:52 AM
Of course I realize they are better than a spinner - but beyond booting up faster - will I see any other benefit to having this SSD in my computer?
I can wait an extra 60 seconds every few days if it saves me $200.
But if it will give me better performance while I am working on a ProTools session (this will be a dedicated computer) then that is a different story.
  #5494
Old 12-08-2013, 01:49 PM
gtrm8kr gtrm8kr is offline
Another question:
It might not be for everyone. My system drive has been hanging out around 90 GB for awhile, so the smaller drive should work fine for me as this is a Pro Tools only PC. The main reason for my switch in the system drive is about moving off of a stock SSD that I'm starting to worry about. If someone isn't confident about system size (including apps) I agree that a larger drive makes the most sense.
PT 12.3 on Win 8.1 Pro, i7-3930k, Sabertooth x79, 16GB G.Skill 2133, Lynx Hilo, Eleven Rack, a "few" guitars...
  #5495
Old 12-11-2013, 08:32 AM
Boot should be faster, general operation faster as well. A common comment from new SSD users is "wow everything just seems faster". If samples are on your boot drive then you benefit from the SSD performance as well. And for many users it may deliver higher performance to out samples on a shared boot/system SSD than use two separate HHDs.
  #5496
Old 12-11-2013, 11:02 AM
Ram
Please guide on selecting the best RAM for new PT 10 build using:
ASUS P9X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
The spec options are: DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066
Does this mean a higher number is better, also some say O.C. which I assume means overclocked. I am in the dark here; can I get please get a quick synopsis of how my choice of RAM makes a difference?
Processor
Also - this processor seems to be the best bang for buck - Would it really be worth nearly twice the price to go with 3930?
Intel Core i7-3820 Sandy Bridge-E 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W Quad-Core Desktop Processor BX80619i73820
Also - this processor is cheaper than a few other models, but it specs seem as good or better, what's the rub? (Compare here: http://www.newegg.com/Product/Produc...el%20Core%20i7)
  #5497
Old 12-11-2013, 06:09 PM
CME CME is offline
I agree. After buying my first SSD, I soon upgraded every computer I own to one. Then I bought a new Mac Pro. Thought I'd do some swapping, the basic end result being I take the SSD out of my laptop for it and put the original drive back in. Albeit it's a 5400 rpm drive, but man was it annoyingly slow. So I found a great deal on a 480GB SSD and am back to all SSD's.
Does it make pro tools faster/better? It sure loads a lot faster. Especially if you have a lot of plugs. May not be any increase in performance once open, but they are getting cheap enough that everyone should own one. At least IMO.
And fwiw I have a 64 GB SSD in the Mac Pro. I use about 45-50 GB of it, and have a bunch of stuff that isn't required for pro tools usage on it. I could really probably get it back down to 20-30 GB used if I wanted. But I'll upgrade to at least a 250ish GB drive soon. And if you have other drives to fill up (mine also has a 500 GB samples/time machine drive, and a 2 TB and 3 TB audio drive), you can get by with a pretty small OS drive.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
  #5498
Old 12-12-2013, 08:45 AM
Okay - I got my computer. I just bought it from eBay and it has all the essential elements I would have purchased new and would have cost me close to $1400. I got it - assembled, for $800 + $50 shipping. Best of all I got a SSD, an upgrade to the motherboard I had picked out and a bigger PSU.
Ebay has a LOT of dealers selling these types of computers in the $1400 range (essentially the cost to build it). I just happened to get lucky and find a guy who just built this but was moving over to MAC. He says it also has a CPU cooling fan.
CPU:
Intel Core i7-3820 Quad-Core Processor 3.6 GHz 4 cores, 8 logical processors ($302.00)
SSD:
OCZ Technology 256GB Vertex 4 Series SATA 6.0 GB/s 2.5-Inch Solid State Drive (SSD) With Industry's Highest 120K IOPS And 5-Year Warranty ($275 being generous here)
Motherboard
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard ($315)
Ram:
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin SDRAM DDR3 1600 (PC3 12800) Desktop Memory F3-1600C10D-16GAO ($169)
Case:
Fractal Design Define R4 Cases, Titanium grey ($120)
Hard Drive (2 SEPARATE hard drives): ($120)
Seagate Barracuda 1TB 7200RPM 64MB SATA 6Gbps 3.5IN
VIDEO CARD: ($150.00)
AMD Radeon HD 6850 1GB DDR5 PCI Express (PCIe) Dual DVI Video Card w/HDMI DisplayPort & HDCP
CD/DVD/BluRay Drive ($70)
LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL Blu-ray Burner, Bare Drive, 3D Play Back (WH14NS40) - OEM
PSU: ($100)
Corsair CX Series CX750 750W ATX 12V 80 Plus Bronze Power Supply Active PFC Fan 140mm Fan
OS: ($140.00)
WINDOWS 7 Professional (64 bit installed)
  #5499
Old 12-19-2013, 12:52 AM
mano111 mano111 is offline
CPU:
SSD:
Motherboard
Ram:
Case:
PSU: ($100)
OS: ($140.00)
Thats a steal! good e-bayin'
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #5500
Old 12-19-2013, 01:34 AM
Thank you, I felt kind of bad that I shut down the conversation here for such a long time, but it was a great deal. It should becoming in by Fedex tomorrow. I also scored a used Digi 003 console and that will be my new core system.
Here is a great eBay buy right now: (ends tomorrow), if I didn't have a brand new 003 I would jump on this:
http://www.ebay.com/itm/161178237731...84.m1438.l2649
Excellent Condition AVID (Euphonix) Artist Control and Artist Mix Console = 1 Bid $599.
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
