recording to & running a session on a USB flash drive
i do wonder...
if i get a 32Gb USB flash drive and format that badboy to use the Mac OS X extended journaled file system, will it be fast enough to run a ProTools LE session with 20 something tracks? my MacBook Pro's internal 5200rpm drive is not even fast enough to record 1 stereo track for more than about a minute, so i am carting around a 500Gb external drive to get the speed of the 7200rpm drive as required by 'tools. If correctly formatted, will ProTools allow me to set a USB flash drive as a record volume? has anyone experiences of trying this or reading about this before? thanks! |
Re: recording to & running a session on a USB flash drive
Ouch, you can expect some harsh replies but the bottom line is no.
I understand where your coming with regard to the size of the externals. I use an OWC on the go FW400 2.5" enclosure, it's great, fits in my bag, completely bus powered and you can buy a drive included or load it yourself. I'm using it with 30 tracks no probs chained to my 002R. Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
I have a couple of these flash drives and they're great for backing up a session to take it somewhere with you....and they keep getting bigger and bigger but no....you can't record audio directly to it during a session. Firewire is always the better way.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core 16 GB RAM Mountain Lion 10.8.5/El Capitan 10.11 Focusrite Saffire Pro 40 Ableton Live 10/Presonus Studio 3 |
i think the only thing worse than recording to your internal hard drive would be to record to a USB flash drive...
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
Well, just for the curious - at the moment I am using 2Gb NTFS formated USB Flash Drive (Maxell) in Vista, and it works just fine for 3-4 audio tracks. Or even more - I should make tests. It gives me about 3.5 Mb/s. Right now I am trying to use another USB thumb drive 4 Gb, formated with the same options, and PT7.4 says it is not valid Audio volume. But it says it is just fine for Video recording
(i.e. PT on 1 int. drive, audio on the 2nd) ? |
mac laptops only have 1 internal.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
yeah I wasn't eluding to using a second internal drive, which a laptop is incapable of, I was talking about your internal system drive. If you have a Mac Pro/Powermac and want to use additional internal drives, they work great. I have two loaded in my machine that I use every day.
As for SJS and his USB thumb drive, let me know when you get the kind of performance that I need, 48 tracks and a bunch of plugins. Why would you consider 3-4 tracks acceptable? You say it like you were impressed. I wish I had the time to play around like that...
I applaud ideas like this, thinking of the USB flash drive. If I had one I would def test it! I also wonder if it really can be better to run an external FW drive sharing the bandwith with, for example, my 002R. After all the USB2 is faster alone than the FW400. I have many times recorded into a USB 2.0. Works super. Yeah, yeah.. I know what Digi says... /Micke
I voted at www.deardigi.com Drummer of Yamaha Birch Absolute Custom Nouveau Vintage Natural - Zildjian K Custom Dark - Sabian HH Macbook (2009-01) 2.0 GHz 4 GB Intel Quad (2007-07) Q6600 2x250 4 GB PT 8 Digirack 002 Monitors: JM-Lab Electra 906 & SW900 driven with Pioneer Reference M-90 "Semiprofessional user" |
Tried it with 8g stick(pretty fast one too)..got errors right of the bat. It would be totally sweet to be able to, for portable users on the run. I've had better luck using the internal 5400 stock drive that came with my macbook. There still has been talk of maybe using it as a loops or samples storage device(but might as well use your firewire drive imho).
Using a 32gb flash drive for audio drive | K-Bomb | Storage Subsystems | 6 | 08-28-2012 08:56 PM |
Protools 10 session running ultra fast when recording while locked to incoming smpte | LiveWire Remote Recorders | Pro Tools HDX & HD Native Systems (Mac) | 0 | 07-29-2012 05:27 PM |
Running MIDI ONLY sessions from USB Flash Drive | AndySolomon | Pro Tools M-Powered (Win) | 1 | 11-23-2010 05:11 AM |
Running PT from a SSD (Solid State Drive), not recording to one - Observations | gheed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-31-2010 11:58 AM |
Running a Vocal recording session | DrSync | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-09-2008 08:02 AM |
