Timestamp oddity or bug
Hi all,
I have a strange time-stamp issue I can't seem to crack. We're recording ADR every week for a TV show shot here in Austin. The session format is 16-bit/48k/SDII. After the session, I compress the sound files using Drop-Stuff and upload the .sitx file to the dialog cutter in L.A.; he drops the files into the show based on the original timestamp information. But there seems to be a consistent offset of 4 seconds 10 frames. I know our timelines are the same because the cue sheets we're getting from LA are accurate to the session we're working on in Austin. I tried to recreate the problem here by dropping in a compressed/uncompressed file, but everything worked fine. The only thing I can think of is that we're recording in PT7, and they are importing into PT5.1. But you would think a time-stamp is a time-stamp, regardless of the application version. Any ideas? Hmmm... maybe it's because we're in a different time zone....
Chris Erlon |
Re: Timestamp oddity or bug
Have them check their session frame rate, clock, sample rate, etc.
Rail
A VI Oddity with PT | DonaldM | Virtual Instruments | 4 | 12-04-2009 10:22 AM |
More Oddity problems | Gothboy | Virtual Instruments | 0 | 11-24-2009 05:02 AM |
Structure oddity | DonaldM | Virtual Instruments | 12 | 11-13-2009 06:05 AM |
No program changes with Oddity? | Gothboy | Virtual Instruments | 0 | 12-14-2007 03:31 PM |
LM100 oddity | marty lester | Post - Surround - Video | 4 | 09-11-2006 04:30 PM |
