Old 03-15-2020, 09:47 AM
Talisker Talisker is offline
Default I doubled my RAM...didn't do much
Hey guys,
see my specs below, please. So a few months ago I replaced my hard drive with a ssd drive that was a smart move. Then came a time when I was running into cpu problems more then often so I decided to give my mac mini the most ram possible which in this case is 16GB.
But I was very disappointed to learn, that this is helping almost nothing. I always thought more RAM was a big deal. Was I wrong ?
And while we're at it, I think there was a page on avids website, that told you ALL the adjustments in both pro tools and your system prefs that help saving cpu power, does anyone still have that link ?
thanx a lot
Kai
Mac Mini 205 Ghz Intel Core i5, 16 GB Ram, OSX 10.8.5, Focusrite Saffire Pro 40,Behringer ADA 8200 Pro Tools 10.3.9, 2xGlyph hard drive 750GB
Old 03-15-2020, 10:08 AM
Michael Carnes's Avatar
Michael Carnes Michael Carnes is online now
Development Partner
Default Re: I doubled my RAM...didn't do much
Originally Posted by Talisker View Post
Hey guys,
Kai
Hey Kai,
Extra RAM can help quite a lot, but only if you're doing something that needs a lot (like virtual instruments).
It's worth getting to know the Activity Monitor program. It's in your Applications/Utilities folder. This is a great tool that will show you exactly what's going on in terms of CPU use and memory use (along with other things). Just run it while you're doing your regular work and you can see exactly how much physical RAM you're using at any given time.
Remember that nature abhors a vacuum. If you're not using all that RAM right now, you will eventually
Old 03-15-2020, 11:01 AM
EGS's Avatar
EGS EGS is offline
PTools 10 is a 32 bit app, so it's limited to 4GB ram.
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.3 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 03-15-2020, 11:31 AM
Damn, that's right....forgot about that, thanx....so maybe, it is time to upgrade at least to PT 11
Old 03-15-2020, 12:57 PM
JFreak JFreak is online now
The way PT is upgraded has changed since PT10 days. Nowadays you need to have active "support and update plan" to get updates, and when you do you can choose from whatever version you wish to use.
Problem is Avid stopped selling "reinstatements" of lapsed support plans last year. You need to find a reseller that sells you that reinstantement and then after "upgrade" you need to keep renewing your support plan every year.
Old 03-15-2020, 01:00 PM
Also take a look at this compatibility info page. With your current OS you can go up to 12.4 but if you upgrade (or rather, wipe hard drive and do a clean install) to High Sierra you can get latest version. You mentioned SSD and with High Sierra you get the new APFS file system that is specifically designed for SSD storage.
Old 03-16-2020, 06:46 AM
Ben Jenssen's Avatar
If you haven't already, set some of those 16gb memory to be used as disk cache in PT so that it loads session into the ram. 5 or 10 gb maybe. That might help PT feel snappier.
As said before, enough ram is all you need, too much ram makes no difference. CPU problems can only be solved by getting more powerful CPU.
Old 03-16-2020, 07:52 AM
EGS's Avatar
EGS EGS is offline
... set some of those 16gb memory to be used as disk cache ...
Nope - he's running PTools 10.
Click for demo
Old 03-16-2020, 09:19 AM
TOM@METRO's Avatar
Right.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-16-2020, 10:24 AM
Oops. Sorry.
ProTools 10 (HDX) with NI Maschine, doubled notes rcarline Pro Tools HDX & HD Native Systems (Mac) 11 10-29-2015 10:19 AM
Session templates doubled up Denby macOS 4 02-01-2014 07:04 AM
Hum in MBox inputs... Hum Eliminator didn't work, blnced cables didn't... dl0banter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-17-2011 07:55 PM
Midi Notes Doubled KirinBenjamin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-02-2002 09:24 AM
DOUBLED VOLUME GRAPHS germ Pro Tools TDM Systems (Mac) 4 06-12-2001 12:16 AM
