Old 06-17-2017, 09:13 AM
sonicflwr sonicflwr is offline
Default PT12 with MacBook Pro Late 2011 (upgraded)
I have been running Pro Tools 9 for as long as I feel possible. The time has come to do the upgrade to PT12.
I have done/am planning on upgrading my MacBook Pro (Late 2011) to a configuration that looks like: 2.5 GHz, Intel Core i7, 16GB RAM, 525GB SSD. And also update OS 10.9.2 to OS 10.12.
On Avids System Requirements/Compatibility Table, the earliest Mac Models are 2012, so I am wondering if anyone has experience with running a newer OS and PT12 on a MacBook Pro 2011 (upgraded)?
Does anyone know if this is possible or will I run into trouble if I try this?
Old 06-18-2017, 05:43 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: PT12 with MacBook Pro Late 2011 (upgraded)
I'm copying my reply from a similar post:
Since switching to an SSD internal drive and external thunderbolt SSD on a 2011 MBP with similar specs, I can run ProTools 12 fine
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 06-20-2017, 11:14 AM
VRW VRW is offline
As mentioned by Chris already this should be definitely no problem as long it´s
an i7 Quad Core processor, you got 16GB Ram and even a SSD for the internal drive.
Just make sure to use a second, separate, fast-enough drive for your Pro Tools sessions+audio files. With a 2011 MBP you have two options.
1) go external...use an external drive via Firewire or Thunderbolt (no USB because those MBPs only got USB2) and only use 7200rpm HDDs or SATA SSDs.
2) go internal...replace your optical drive with a second, internal, fast-enough drive for your PT audio.
https://eshop.macsales.com/item/OWC/DDAMBS0GB/
You again may use a 7200rpm HDD or a SSD (for your MBP model OWC SSDs may be a reliable choice).
If you use VIs with large sample libraries you even may use another, third drive for these samples only. Again, the same specs needed for this drive like for
the PT audio drive.
Finally don´t forget to set up the Pro Tools optimizations for the dedicated version of macOS and you should be good to go.
http://avid.force.com/pkb/articles/t...Optimize-10-12
All the best!
Old 06-21-2017, 12:28 AM
WarrenG WarrenG is offline
the PT audio drive.
All the best!
One word of warning - if using the internal option then be aware that some SSDs don't work in the optical drive slot. I have a Crucial M500 1TB SSD and a Samsung EVO 850 1TB SSD and the Crucial drive doesn't work in the optical drive bay. I've updated my firmware to allow the 6Gb/s transfer too. If I put the Samsung in the optical bay and the Crucial in the main SATA bay then all works fine.
The Samsung has much netter transfer rates too and I now wouldn't touch anything else...
Best regards
Warren
Website
FaceBook
MySpace
Old 06-30-2017, 05:36 PM
fourthtunz fourthtunz is offline
I have a 2012 and 2011, MacBook pros most of what I do is on the 2012 15"
I7 2.7 I've been running 12.8 and Mac OS 10.12.5, with a 960 gig SSD internal and ran the same mixes and bounced to the internal SSD, a firewire, a USB3 and the SD card all with great results. If I used the SD card as the boot drive it didn't seem to work as well.(that was on 46 tracks at (96k)
You may want to look at the 2012 MacBook pros as they have USB 3 ports.
PT12 on 2011 MBP, 4GB RAM [solved] jdogric12 Pro Tools 12 46 08-09-2016 07:36 AM
MacBook Pro 13" (late 2011) with PT 10 musikasik macOS 5 01-12-2013 10:29 AM
MacBook Pro 17 Late 2011, Magma 4-slot, HD4... no go Mauro371 Pro Tools TDM Systems (Mac) 18 12-22-2011 04:00 AM
Can Pro tools use 16gb ram on a Macbook Pro late 2011 trajan24 macOS 2 12-20-2011 10:02 PM
Can Pro tools use 16gb ram on a Macbook Pro late 2011 trajan24 Pro Tools 10 9 12-19-2011 09:12 PM
